Routing return traffic for OpenVPN
Paul Martin
I'm by no means a "network tech" however, I'm just technical enough to get in trouble.  I have been banging my head over this problem for roughly a month now.  This is my first post, ANY advice is welcome, as I'm sure the below config could be optimized.
Scene setter:
I'm currently serving overseas, and would like to be able to route my overseas network traffic over a VPN back to my home to obtain my US ISP IP to watch "American" TV.  I have an OpenWrt client in my overseas location connected and working to my OpenWrt OpenVPN server.
The OpenVPN server sits behind a Cisco 2821 router running IOS 15 that is connected to a bridged cable modem to my ISP with the FW turned off and all passthrough turned on.  My VPN tunnel works flawlessly to my LAN, as if I'm sitting in my chair at home (in fact I'm remoted into my home Server to send this) however, I cannot get out to the internet via ping, or via DNS.
My LAN operates on the 10.0.0.0/24 network, and I have my VPN riding the 10.1.1.1/24 network, using port 10001
(You will also note I have a Cisco VPN set up to run a soft Cisco VPN client, it too only accesses the LAN-initially by design)
Below is my config (not sure how to post just the code, please forgive the mess):
R1#sh run
Building configuration...
Current configuration : 8383 bytes
! Last configuration change at 18:30:40 UTC Mon Apr 11 2016 by me
version 15.1
service config
hostname R1
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$3FMk$ainv0tC4YAqCxszYuytLO/
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
dot11 syslog
no ip source-route
ip cef
ip dhcp excluded-address 10.0.0.1 10.0.0.30
ip dhcp pool test
 import all
 network 10.0.0.0 255.255.255.0
 dns-server 8.8.8.8
 default-router 10.0.0.1
ip dhcp pool Switch
 host 10.0.0.4 255.255.255.0
 client-identifier 0100.1c10.1c3c.3f
 client-name Cisco-Linksys
ip dhcp pool Receiver
 host 10.0.0.5 255.255.255.0
 client-identifier 0100.05cd.2240.4d
 client-name Denon
ip domain name my.server.com
ip name-server 8.8.8.8
ip name-server 216.146.35.35
ip name-server 216.146.36.36
ip dhcp-client update dns server both
no ipv6 cef
voice-card 0
crypto pki trustpoint TP-self-signed-4170320544
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-4170320544
 revocation-check none
 rsakeypair TP-self-signed-4170320544
crypto pki certificate chain TP-self-signed-4170320544
 certificate self-signed 01
 6E65642D 3082022B 30820194 A0030201 494F532D 02020101 300D0609 2A864886
  31312F30 2D060355 F70D0101 04031326  53656C66 2D536967 43657274 05050030
        quit
license udi pid CISCO2821 sn FTX1332AJ9S
username Bionic privilege 10 secret 4 0.7.5uddTBi..dB4EPD5drOljE5DbmC6EYgRLs4zCH2
username paulypizal privilege 15 view root secret 4 KUn3Nj47kw9Gsfo508bVJjzZZpn9QmzJ7os7Kxl7yuw
username admin privilege 15 secret 4 KUn3Nj47kw9Gsfo508bVJjzZZpn9QmzJ7os7Kxl7yuw
redundancy
no ip ftp passive
ip ssh port 2022 rotary 1
class-map type inspect match-any SDM_AH
 match access-group name SDM_AH
class-map type inspect match-any SDM_ESP
 match access-group name SDM_ESP
crypto ctcp port 10000
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp client configuration group Home
 key xxxxxxxxxxxxx
 pool SDM_POOL_1
 acl 101
 include-local-lan
 max-users 5
 netmask 255.255.255.0
 banner ^CYou have reached My ROUTER!^C
crypto isakmp profile ciscocp-ike-profile-1
   match identity group Home
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
 set security-association idle-time 1800
 set transform-set ESP-3DES-SHA
 set isakmp-profile ciscocp-ike-profile-1
interface Loopback0
 ip address 172.16.0.1 255.255.255.0
interface GigabitEthernet0/0
 description Outside World$FW_OUTSIDE$
 ip address dhcp
 ip flow ingress
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 description Inside World$ETH-LAN$$FW_INSIDE$
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface Virtual-Template1 type tunnel
 ip unnumbered Loopback0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile CiscoCP_Profile1
ip local pool SDM_POOL_1 172.16.0.2 172.16.0.50
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http secure-port 8443
ip flow-export destination 10.0.0.69 2055
ip dns server
ip nat inside source list 2 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.0.0.10 8080 interface GigabitEthernet0/0 8080
ip nat inside source static tcp 10.0.0.10 32400 interface GigabitEthernet0/0 32400
ip nat inside source static tcp 10.0.0.10 8083 interface GigabitEthernet0/0 8083
ip nat inside source static tcp 10.0.0.10 22 interface GigabitEthernet0/0 22
ip nat inside source static tcp 10.0.0.10 80 interface GigabitEthernet0/0 80
ip nat inside source static tcp 10.0.0.9 8084 interface GigabitEthernet0/0 8084
ip nat inside source static tcp 10.0.0.10 5050 interface GigabitEthernet0/0 8085
ip nat inside source static tcp 10.0.0.15 3074 interface GigabitEthernet0/0 3074
ip nat inside source static udp 10.0.0.15 3074 interface GigabitEthernet0/0 3074
ip nat inside source static tcp 10.0.0.12 1723 interface GigabitEthernet0/0 1723
ip nat inside source static udp 10.0.0.3 10001 interface GigabitEthernet0/0 10001
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 196.xxx.xxx.1
ip route 10.1.1.0 255.255.255.0 10.0.0.3  ## I had to add this for OpenVPN LAN access
ip access-list extended vtyacl
 remark left open for ANY restrict later to IP
 remark CCP_ACL Category=17
 permit ip 10.0.0.0 0.0.0.255 any
 permit tcp any any eq 2022
access-list 1 permit any
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 10.0.0.0 0.0.0.255
access-list 100 permit ip any any
access-list 101 remark CCP_ACL Category=4
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 101 permit ip any any
access-list 102 remark CCP_ACL Category=128
access-list 102 permit ip host 255.255.255.255 any
access-list 102 permit ip 127.0.0.0 0.255.255.255 any
access-list 105 remark CCP_ACL Category=1
access-list 105 permit tcp any any eq 10000
access-list 106 remark CCP_ACL Category=1
access-list 106 permit tcp any any eq 10000
snmp-server community public RO
snmp-server ifindex persist
control-plane
mgcp profile default
banner login ^CCCWelcome to the Martin Router!^C
line con 0
line aux 0
line vty 0 3
 access-class 101 in
 password xxx
 transport input all
line vty 4
 access-class vtyacl in
 password xxx
 rotary 1
 transport input ssh
line vty 5 15
 rotary 1
 transport input ssh
line vty 16 924
 access-class 102 in
 no exec
 transport input none
scheduler allocate 20000 1000
ntp update-calendar
ntp server pool.ntp.org
end
R1#sh ip inter
GigabitEthernet0/0 is up, line protocol is up
  Internet address is 96.59.238.190/18
  Broadcast address is 255.255.255.255
  Address determined by DHCP
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Ingress-NetFlow, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
  Output features: Post-routing NAT Outside, Stateful Inspection, NAT ALG proxy, Post-Ingress-NetFlow
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
GigabitEthernet0/1 is up, line protocol is up
  Internet address is 10.0.0.1/24
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Network address translation is enabled, interface in domain inside
  Input features: Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
  Output features: NAT Inside, Stateful Inspection, NAT ALG proxy, Post-Ingress-NetFlow
Loopback0 is up, line protocol is up
  Internet address is 172.16.0.1/24
  MTU is 1514 bytes
  IP Null turbo vector
  Network address translation is disabled
  Input features: MCI Check
  Output features: Post-Ingress-NetFlow
NVI0 is up, line protocol is up
  Interface is unnumbered. Using address of Loopback0 (172.16.0.1)
  MTU is 1514 bytes
  IP fast switching is disabled
  IP CEF switching is disabled
  Output features: Post-routing NAT NVI Output, Post-Ingress-NetFlow
Virtual-Template1 is up, line protocol is down
  MTU is 1500 bytes
  Post encapsulation features: IPSEC Post-encap output classification
R1#sh ip access-lists
Standard IP access list 1
    10 permit any (58 matches)
Standard IP access list 2
    10 permit 10.0.0.0, wildcard bits 0.0.0.255 (803361 matches)
Extended IP access list 100
    10 permit ip any any
Extended IP access list 101
    10 permit ip 10.0.0.0 0.0.0.255 any (4664 matches)
    11 permit ip 10.1.1.0 0.0.0.255 any (567 matches)
    12 permit ip any any (5396 matches)
Extended IP access list 102
    10 permit ip host 255.255.255.255 any
    20 permit ip 127.0.0.0 0.255.255.255 any
Extended IP access list 105
    10 permit tcp any any eq 10000
Extended IP access list 106
Extended IP access list vtyacl
    10 permit ip 10.0.0.0 0.0.0.255 any (2 matches)
    20 permit tcp any any eq 2022 (17 matches)
R1#
______________________________________________________________________________________________________________________________________________________________________________________________________________________________________
From Overseas LAN:
C:\Users\Paul>route print
Interface List
  9...f0 1f af 1f 97 c9 ......Realtek PCIe FE Family Controller
 10...1e 85 56 78 f9 49 ......Microsoft Wi-Fi Direct Virtual Adapter
 24...02 c0 c8 28 89 01 ......BlackBerry Virtual Private Network
 29...00 ff f6 42 c4 39 ......TAP-Windows Adapter V9
 23...bc 85 56 78 f9 49 ......Dell Wireless 1705 802.11b/g/n (2.4GHZ)
 13...bc 85 56 78 f9 4a ......Bluetooth Device (Personal Area Network)
  1...........................Software Loopback Interface 1
 28...00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
 14...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #4
 57...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #5
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.1.1    192.168.1.127     25
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
      169.254.0.0      255.255.0.0         On-link   169.254.211.218    261
  169.254.211.218  255.255.255.255         On-link   169.254.211.218    261
  169.254.255.255  255.255.255.255         On-link   169.254.211.218    261
      192.168.1.0    255.255.255.0         On-link     192.168.1.127    281
    192.168.1.127  255.255.255.255         On-link     192.168.1.127    281
    192.168.1.255  255.255.255.255         On-link     192.168.1.127    281
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link     192.168.1.127    281
        224.0.0.0        240.0.0.0         On-link   169.254.211.218    261
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link     192.168.1.127    281
  255.255.255.255  255.255.255.255         On-link   169.254.211.218    261
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  1    306 ::1/128                  On-link
 28    306 2001::/32                On-link
 28    306 2001:0:5ef5:79fd:ac:3819:d1db:37a4/128
                                    On-link
 24    261 fd00::/8                 On-link
 24    261 fd10:15f5:6404:9df4:2fab:695f:a5f1:e2e0/128
                                    On-link
 24    261 fe80::/64                On-link
 28    306 fe80::/64                On-link
 28    306 fe80::ac:3819:d1db:37a4/128
                                    On-link
 24    261 fe80::b8f7:4175:c9b4:d3da/128
                                    On-link
  1    306 ff00::/8                 On-link
 28    306 ff00::/8                 On-link
 24    261 ff00::/8                 On-link
Persistent Routes:
  None
C:\Users\Paul>
VPN Through my house w/ connected tunnel:
Interface List
  8...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
IPv4 Route Table
Active Routes:
          0.0.0.0        128.0.0.0         10.1.1.1         10.1.1.2     20
         10.0.0.0    255.255.255.0         10.1.1.1         10.1.1.2     20
         10.1.1.0    255.255.255.0         On-link          10.1.1.2    276
         10.1.1.2  255.255.255.255         On-link          10.1.1.2    276
       10.1.1.255  255.255.255.255         On-link          10.1.1.2    276
    96.59.238.190  255.255.255.255      192.168.1.1    192.168.1.127     25
        128.0.0.0        128.0.0.0         10.1.1.1         10.1.1.2     20
        224.0.0.0        240.0.0.0         On-link          10.1.1.2    276
  255.255.255.255  255.255.255.255         On-link          10.1.1.2    276
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
                                    On-link
                                    On-link
Persistent Routes:
  None
______________________________________________________________________________________________________________________________________________________________________________________________________________________________________  C:\Users\Paul>
Trace Route to Google thru my OpenVPN, stops at my bridged cable modem, firewall off 192.168.0.1:
C:\Users\Paul>tracert 8.8.8.8
Tracing route to google-public-dns-a.google.com [8.8.8.8]
over a maximum of 30 hops:
  1   153 ms   254 ms   262 ms  10.1.1.1                       #Home OpenVPN Server
  2   133 ms   136 ms   138 ms  Martin [10.0.0.1]     #Gateway Cisco Router
  3   127 ms   132 ms   133 ms  192.168.0.1                #Bridged Cable Modem
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7
A trace route to google not connected via VPN and from my house gets there:
C:\Users\Alien>tracert www.google.com
Tracing route to www.google.com [64.233.185.104]
1 <1 ms <1 ms <1 ms 10.0.0.1
2 1 ms <1 ms <1 ms 192.168.0.1
3 * * * Request timed out.
4 9 ms 5 ms 4 ms ten0-6-0-0.tamp20-car2.bhn.net [71.44.1.106]
5 9 ms 7 ms 12 ms 72-31-117-26.net.bhntampa.com [72.31.117.26]
6 14 ms 14 ms 12 ms 72-31-6-178.net.bhntampa.com [72.31.6.178]
7 17 ms 16 ms 12 ms ten0-3-0-2.ORLD71-CAR2.bhn.net [72.31.196.142]
8 16 ms 13 ms 16 ms hun0-3-0-9.ORLD71-cbr1.bhn.net [72.31.220.242]
9 18 ms 15 ms 15 ms 10.bu-ether15.orldfljo00w-bcr00.tbone.rr.com [66
.109.6.98]
10 25 ms 30 ms 23 ms bu-ether18.atlngamq47w-bcr01.tbone.rr.com [66.10
9.1.72]
11 21 ms 21 ms 29 ms 0.ae3.pr1.atl20.tbone.rr.com [107.14.17.190]
12 40 ms 40 ms 37 ms ix-ae-14-0.tcore1.A56-Atlanta.as6453.net [64.86.
113.37]
13 38 ms 39 ms 39 ms 72.14.221.82
14 41 ms 42 ms 35 ms 72.14.233.54
15 39 ms 34 ms 39 ms 216.239.51.243
16 36 ms 39 ms 36 ms 64.233.174.133
17 * * * Request timed out.
18 37 ms 35 ms 37 ms yb-in-f104.1e100.net [64.233.185.104]
Trace complete.
My thinking is that there must be some type of routing command that is not letting traffic find it's way back to the 10.1.1.0/24 network.
Any info provided is much appreciated, and again sorry for the mess!
v/r
Paul
Philip D'Ath
Add this one line:
access-list 2 permit 10.1.1.0 0.0.0.255
Philip D'Ath
Add this one line:
Another low cost option is to deploy a proxy server at home (bit hard when you are not there). Squid + a Raspberry Pi 3 would be a cheap option.
Paul Martin
Mr. Philip,
I would buy you a beer right now if I was home!!  I new it would be something as simple as that, but staring at it for hours and hours, I just missed it.
I'll research your secondary option when I return.  For now, I appreciate you taking the time here.
v/r
Paul
I suspect buying me a beer would be just as tricky now as when you get home, as my home is probably more than a couple of km's away from yours.  :-)
Auckland, New Zealand
