routing table prefers the longest match..I want to modify this behavior.
nikhil.kulkarni
Hi Folks,
For some requirements I need to block some routes into our network. To give you a example say I want to block 1.1.0.0 /16 in my network, I have done so by adding a static Null route on our ISP facing router.
Now the drawback for this solution really comes on when I see a route matching a specific prefix being learnt by BGP, example 1.1.1.0 /24 being learnt and not being blocked.
What could be the recommendation to achieve this?
Nikhil Kulkarni.
cadet alain
let's suppose you want to block 1.1.1.0/24 learned via BGP:
ip prefix-list BLOCK_PREF deny 1.1.1.0/24
ip prefix-list BLOCK_PREF permit 0.0.0.0/0 le 32
router bgp xxx
neighbor x.x.x.x  prefix-list in
do clear ip bgp neighbor x.x.x.x in
Regards.
Alain
Giuseppe Larosa
Hello Nikhil,
Hello Nikhil,
you need to implement route filtering in the inbound receiving direction.
Following your example if you want to be sure that your router will not accept any specific route within address block 1.1.0.0/16 you can use a prefix-list like
ip prefix-list UNWANTED_ROUTES  permit 1.1.0.0/16 le 32
route-map  INBOUND  deny 10
match ip address prefix UNWANTED_ROUTES
! next empty route-map block to allow all other routes
route-map INBOUND permit 20
router bgp
neigh x.x.x.x route-map INBOUND in
For each address-block you want no component route to be accepted you will add a line to prefix-list UNWANTED_ROUTES like
ip prefix-list UNWANTED_ROUTES  A.B:C:D/len  le 32
Hope to help
Giuseppe
