iBGP configuration between two Routers and one Switch
Dipesh Patel
Level 2
Level 2
Dear experts,
Kindly suggest for the iBGP configuration between two routers and One CORE switch as shown in diagram :
1. iBGP between CE Router A to L3 switch
2. iBGP between CE Router B to L3 switch
3. iBGP between CE Router A to CE Router B
Is ok or I should not configure iBGP between Router to Route and break a loop?
In both the case on router should I configure : neighbor X.X.X.X next-hop-self?
is it required to configure : neighbor X.X.X.X next-hop-self on CORE switch?
Giuseppe Larosa
Duplicated post
Best Regards
Giuseppe
