Routing table supernet is incorrect
Darren Sasso
Has anyone seen this before.  The supernet shows up as a /24 and the new vlan 2 doesn't have a subnet assigned to it.
4506#sh ip ro
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.128.66.0 is directly connected, Vlan2
C    192.168.1.0/24 is directly connected, Vlan1
C    192.168.3.0/24 is directly connected, Vlan10
We are running this on an old supervisor.  It may be an IOS bug issue but i'm not sure.
Thanks in advance.
22 Replies 22
I think this is because the 4500 has a directly connected subnet 10.128.66.0/24
That's why the routing table shows that from the 10.0.0.0, there's a subnet with mask /24
If you happen to have another subnet from the 10.0.0.0 directly connected, say 10.126.1.0/27 then the routing table will show:
     10.0.0.0/8 is subnetted, 1 subnets
C       10.128.66.0/24 is directly connected, Vlan2
C       10.126.1.0/27 is directly connected, VlanX
Federico.
Richard Burts
Darren
I have not seen something like that before. Perhaps we could provide better answers if we knew more of what you are trying to do. Would it be possible that you could post relevant parts of the config (interface config, any route statements)?
I am puzzled by your statement that Vlan2 does not have a subnet assigned to it. The routing table shows that there is a /24 subnet associated with Vlan2
Rick
Rick
I am just creating a new VLAN and i'm having access issues.  The routing table only contains a default route. Below is adding 2 /24 but still the same supernet.
VLAN 2:
interface Vlan2
description USER_VLAN
ip address 10.128.66.1 255.255.255.0
ROUTING TABLE:
     10.0.0.0/24 is subnetted, 2 subnets
C       10.128.65.0 is directly connected, Vlan6
S*   0.0.0.0/0 [1/0] via 192.168.1.1
STATIC DEFAULT:
ip route 0.0.0.0 0.0.0.0 192.168.1.1
Thanks.
I might be wrong but I don't see any problem with this:
This is because there are two VLANs with mask /24, that's why you get the above output.
Does not matter there's no routes in the routing table, the 4500 will add the directly connected routes as soon as the interfaces are functional.
What I'm saying is that if you add another VLAN with a different mask i.e. /27 the output of the supernet will be different. I migth be wrong but give it a try if you can.
Federico.
I guess your right.
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.10.10.0/27 is directly connected, Vlan6
Ultimately i'm getting an error on my pix firewall stating that is doesn't have a route so this looked interesting.
110001: No route to 10.128.66.50 from 172.19.1.208
Ok, now the PIX does not have a way to reach 10.128.66.50?
If you check the routing table on the PIX is there a route to that IP? ''sh route''
If not, you need to check if the PIX and the 4500 share an IP subnet and include the proper route.
Federico.
Darren
This additional information is helpful. So the problem is on your firewall and not on your switch.
Can you post the output of show route from the firewall?
Rick
Rick
Darren
The routing table as you post it is saying that network 10.0.0.0 is subnetted with a single mask which is a /24. This agrees with the interface config that you posted.
If you are having access issues I do not see anything in the routing table that would create access issues. Can you tell us a bit more about what you are trying to do and what is not working?
If your access issue is a problem with a machine in one VLAN attempting to communicate with a machine in another VLAN then here are some steps I would suggest to troubleshoot the problem:
- do both of the machines show up in the ARP table? If not this is a problem and figure out why they are not in the ARP table.
- do the machines have the correct default gateway configured (which should be the VLAN interface address of the switch)?
- starting from one machine verify that
__ can it ping its own default gateway address (the VLAN address on the switch)?
__ can it ping the address of the other VLAN interface of the switch?
- can you verify that ip routing is enabled on the switch?
Rick
Rick
Ok the routing table looks good.  I have 2 machines at different locations that are trying to communicate but i'm having access issues.  I can ping between both machines but i'm unable to web or https.  The only thing i see is the firewall is stating no route which lead me to believe that there was a routing table issue.  I'll have to dig into it a bit more since i know all access lists allow access and i have a nonat in place.  Thank you both for responding.
If you can PING I don't think there's a routing issue.
However check the routing and permissions (ACLs) and also the NAT config.
If you need any more help let us know.
Federico.
Darren
If I am understanding correctly you say that the 2 machines can ping each other. For that to happen it would seem that the PIX would have routes for both subnets. So I am puzzled at the error message on the PIX about no route to subnet.
If 2 machines can ping each other and can not run other applications, such as web, then my first instinct is to look for access list issues. If you check and verify that access lists are permitting the traffic, then my second instinct would be to look at translations and see if something is translated differently for ping or for web.
It also puzzles me what the topology is. Where are these machines and what do they connect to? I had been assuming that both of them are connected to your switch. But if they are connected to the switch then how does the PIX get into the traffic? Perhaps you can provide a better explanation of the topology?
Rick
Rick
Show route from the firewall is below.
506# sh route
        outside 0.0.0.0 0.0.0.0 192.168.2.2 1 OTHER static (System i'm trying to connect to and i'm able to ping)
        inside 10.128.66.0 255.255.255.0 192.168.1.6 1 OTHER static (Source system on 4506 switch)
        inside 192.168.1.0 255.255.255.0 192.168.1.1 1 CONNECT static
        outside 192.168.2.0 255.255.255.0 192.168.2.1 1 CONNECT static
        inside 192.168.3.0 255.255.255.0 192.168.1.6 1 OTHER static
access-list 102 line 60 permit ip 10.128.64.0 255.255.252.0 172.16.0.0 255.240.0.0 (IPSEC Tunnel Traffic)
access-list nonat line 27 permit ip 10.128.64.0 255.255.252.0 172.16.0.0 255.240.0.0 (nonat)
access-list outgoing line 37 permit tcp 10.128.64.0 255.255.252.0 any eq www (inside out traffic from source system)
Peter Paluch
I would like just to confirm what has been said by other friends here. The output you have quoted is a Cisco-specific (and very confusing) way of telling you that all subnetworks of the major network (not a supernet!) 10.0.0.0/8 are currently having the same netmask of /24, so it is not necessary to indicate this mask to each and every subnet. As soon as you subnet the network using different netmasks, this output will be replaced by the line 10.0.0.0/8 is variably subnetted and the individual netmasks will be indicated along the subnets in further output.
Perhaps somebody though years ago that this is a fine way how to make a brief output - instead of indicating the same mask on each subnet of a major network (which was common during the classful ages), the subnet mask used to subnet the major network is indicated in the "headline". Nowadays, unfortunately, it is much more confusing than helpful.
Best regards,
Peter
Thanks Peter that is confusing but it now makes sense.
Output from the firewall and thanks for working with me on this guys.   I'm getting the output from the other firewall too.
506# sh route
nat (inside) 0 access-list nonat
