Routing through an IPSEC tunnel
ianmoroney
Hi guys,
I'll try to explain this as simply as I can and I hope someone can tell me if this is possible, and how to do it.
I have an ASA 5510 configuration that I'd like to add to.
In this configuration there is a site to site IPSEC VPN tunnel to a remote location.
It is tunneling a particular subnet for me and everything is working.
In the remote subnet, there is an ASA 5525-x connected on the outside interface. Let's say for argument's sake, the outside IP is 210.0.0.1
On the Inside interface, i've configured 10.240.32.0/24 network.
The only static route I have configured on the 5510 is the default gateway that goes to the ISP.
I assumed that I have to add: route Outside 10.240.32.0 255.255.255.0 210.0.0.1 1
I did this, but i'm not able to reach the destination 10.240.32.0/24 network. I can't see anything hitting the 5525-x and the only thing I see on the 5510 is the building outbound ICMP and the teardown for the ICMP.
Do I need to add a nat rule?
6 Replies 6
SlevinKelevra
So to draw it out we have the following
Site A (ASA 5510) IP SEC ========= CLOUD ======== IP SEC (ASA 5525) Site B 210.0.0.1 and 10.240.32.0/24
- Add a static route from Site A to the outside interface of Site B to reach 10.240.32.0/24
- Add a static route from Site B to the outside interface of Sita A to reach
- Can you ping the outside interface of site B?
- Does the ASA5510 has a routing entry for 10.240.32.0/24?
- Does the ASA5510 has a routing entry for the the source adres?
- Does the ASA5525 has a routing entry for 10.240.32.0/24?
- Does the ASA5525 know how to get back to the source adres?
NAT shouldnt really make a difference here, routing stays the same, unless i overlooked something.
I think you just forgot to route the traffic back, just my 2 cents.
Please paset your config here.
Well,
The IPSEC tunnel doesn't terminate at the 5525. The 5525 just happens to be sitting on the network that is terminated.
I've done a small diagram to illustrate.
If 210.0.0.1 is reachable that is good!, i presume you are not using NAT.
- Since your directing your traffic to 210.0.0.1 does he know how to reach 10.240.32.0?
- Does your network nodes 10.240.32.0 know how to get back to 10.240.24.0? (should make a default to 210.0.0.1)
To be fair, you should point your traffic to the point where the IP sec tunnel is ending, can still work otherwise, but i think it is cleaner.
PS: Is it possible to use a routing protocol for this like EIGRP, OSPF, evn RIPv2 would work, saves you a lot of hazzle with the statics
10.240.32.0 is the inside interface of the 5525. 210.0.0.1 is the outside of the 5525 so yep they can contact each other.
The problem i have is that 10.240.24.0 won't talk to 10.240.32.0
I may not be able to enable those routing protocols, and I'm happy to have static routes set for now.
Do a traceroute back from one of your nodes (PC?) to 10.240.24.0, where it stops there you can find the missing static route.
