3845-MB dropping pings to its own serial interface.
OSIManiac
Good day friends!
I'm having an issue that I can't quite understand. I set up a test lab to get familiar with EIGRP routing. I have a Cisco 3845-MB with 2
VWIC2-2MFT-T1/E1 cards.
sh ip int brief shows UP UP status on all serial ports. I gave it an IP address but I'm having trouble pinging the serial interface IP. It's dropping pings to its own S 1/1/0 interface when pinging from console. I have known good T1 crossover cables 1&2 - 4&5.
Here is the "ip int brief" from 3845-MB
3845-MB#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
GigabitEthernet0/0         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1         172.30.2.1      YES NVRAM  up                    up
Serial1/1/0:0              10.3.29.2       YES manual up                    up
Right now it's pinging itself at about 60 -90% success rate... and I can't figure out why it's dropping any packets at all. I have other issues with in the lab as well... but i think this might be my "core" issue.
To make matters even more "weird" I've tried two different VWIC2-2MFT-T1/E1 cards and I drop pings with both of them. :-/
Thanks in advance to all who take the time to help!
Here is a sh run and a sh diag:
3845-MB#sh run
Building configuration...
Current configuration : 1434 bytes
version 12.4
hostname 3845-MB
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
! card type command needed for slot/vwic-slot 0/2
! card type command needed for slot/vwic-slot 1/0
logging console critical
no aaa new-model
resource policy
no network-clock-participate slot 1
ip subnet-zero
ip cef
voice-card 0
no dspfarm
controller T1 0/2/0
framing esf
clock source line independent
linecode b8zs
controller T1 0/2/1
framing esf
linecode b8zs
controller T1 1/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
description T1 to LASVEGAS
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/1
ip address 172.30.2.1 255.255.255.0
duplex auto
speed auto
media-type rj45
negotiation auto
interface Serial1/1/0:0
ip address 10.3.29.2 255.255.255.0
ip classless
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 3000 0
privilege level 15
no login
scheduler allocate 20000 1000
end
sh diag
3845 Backplane EEPROM:
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-23093-01
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 04
        PCB Serial Number        : FOC10510M1S
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Part Number              : 73-8639-04
        CLEI Code                : IPME110BRA
        Chassis Serial Number    : FTX1102A3S9
        Product (FRU) Number     : CISCO3845
        Version Identifier       : V01
        Hardware date code       : 20061219
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 04 2B 41 01 00 C0 46 03 20 00 5A 35 01
          0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 30 35 31 30 4D 31 53 03 00 81 00 00 00 00 04 00
          0x30: 82 49 21 BF 04 C6 8A 49 50 4D 45 31 31 30 42 52
          0x40: 41 C2 8B 46 54 58 31 31 30 32 41 33 53 39 CB 92
          0x50: 43 49 53 43 4F 33 38 34 35 20 20 20 20 20 20 20
          0x60: 20 20 89 56 30 31 20 83 01 32 1C 23 FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
       Backplane Registers
   Backplane Revision:              00BE
   Power Supply Status:             F50F
   -48V PS and Env Status:          FFFF
   -48V Isolation Control:          0007
   Backplane Cookie:                000C
   ENM/Backplane FPGA Revision:     00BE
   ENM/Backplane FPGA Int0 Status:  FFFF
   ENM/Backplane FPGA Int2 Status:  00FF
   ENM/Backplane FPGA Int4 Status : EF00
   ENM Interrupt Mask:              0001
   ENM/BP FPGA Interrupt 4 Mask:    0040
   ENM1 Test Port:                  00C3
   ENM2 Test Port:                  00C3
   ENM3 Test Port:                  00C3
   ENM LED Control:                 0011
   ENM OIR Control:                 0000
   ENM OIR Status:                  9299
   ENM PCI Speed Status             000E
   Backplane FPGA Diag Int Control: FFFF
   ENM1 OIR State Machine Status:   C441
   ENM2 OIR State Machine Status:   4141
   ENM3 OIR State Machine Status:   0000
   ENM4 OIR State Machine Status:   0000
   Backplane Voltage Margin:        0000
Slot 0:
        C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapt
er, 13 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        Onboard VPN             : FW ver01100200
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC10520T0F
        Hardware Revision        : 1.3
        Top Assy. Part Number    : 800-23616-05
        Board Revision           : A0
        Deviation Number         : 86930
        Fab Version              : 05
        RMA History              : 00
        Processor type           : 69
        Product (FRU) Number     : CISCO3845-MB
        Version Identifier       : V05
        Chassis MAC Address      : 001a.a206.2a20
        MAC Address block size   : 48
        Part Number              : 73-8799-08
        Hardware date code       : 20061226
          0x00: 04 FF C1 8B 46 4F 43 31 30 35 32 30 54 30 46 40
          0x10: 04 2C 41 01 03 C0 46 03 20 00 5C 40 05 42 41 30
          0x20: 88 00 01 53 92 02 05 03 00 81 00 00 00 00 04 00
          0x30: 09 69 C6 8A 49 50 4D 45 31 31 30 42 52 41 CB 8C
          0x40: 43 49 53 43 4F 33 38 34 35 2D 4D 42 89 56 30 35
          0x50: 20 D9 02 40 C1 C3 06 00 1A A2 06 2A 20 43 00 30
          0x60: 82 49 22 5F 08 83 01 32 1C 2A C2 8B 46 54 58 31
          0x70: 31 30 32 41 33 53 39 FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8541-05
        Board Revision           : A0
        Fab Version              : 04
        PCB Serial Number        : FOC10523637
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-64
          0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 41 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 35 32
          0x20: 33 36 33 37 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-02
        Board Revision           : A0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC10501BSD
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        CLEI Code                : CNUIAPRAAA
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 02
          0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 30 35 30 31 42 53 44 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 31 20
          0x40: C6 8A 43 4E 55 49 41 50 52 41 41 41 FF FF FF FF
        WIC Slot 1:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : A0
        Fab Version              : 04
        PCB Serial Number        : FOC10520RLN
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 41 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 30 35 32 30 52 4C 4E 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
        WIC Slot 2:
        Board Revision           : A0
        Fab Version              : 04
        PCB Serial Number        : FOC10520RNV
        RMA History              : 00
          0x20: 30 35 32 30 52 4E 56 03 00 81 00 00 00 00 04 00
Slot 1:
        NM-2W Port adapter
        Top Assy. Part Number    : 800-04799-02
        Board Revision           : A0
        Fab Version              : 05
        PCB Serial Number        : FOC104860NV
        RMA History              : 00
        Product (FRU) Number     : NM-2W
          0x00: 04 FF 40 00 D6 41 01 00 C0 46 03 20 00 12 BF 02
          0x10: 42 41 30 80 00 00 00 00 02 05 C1 8B 46 4F 43 31
          0x20: 30 34 38 36 30 4E 56 03 00 81 00 00 00 00 04 00
          0x30: CB 85 4E 4D 2D 32 57 89 56 30 31 20 FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        Board Revision           : A0
        Fab Version              : 04
        PCB Serial Number        : FOC10520RGT
        RMA History              : 00
          0x20: 30 35 32 30 52 47 54 03 00 81 00 00 00 00 04 00
        WIC Slot 1:
        T1 (1 port) Multi-Flex Trunk WAN daughter card
        Hardware revision 1.0           Board revision B0
        Serial number     35483656      Part number    800-03568-04
        FRU Part Number   VWIC-1MFT-T1=
        Test history      0x0           RMA number     00-00-00
        Connector type    PCI
        EEPROM format version 1
          0x20: 01 20 01 00 02 1D 70 08 50 0D F0 04 00 00 00 00
          0x30: 58 00 00 00 06 12 22 00 FF FF FF FF FF FF FF FF
In case of Serial and ATM, when you ping the local IP of the interface, packet goes first to the other end and then come back! This is just how they are designed. So, to check the issue, if you don't see any drops locally on the router then try checking the show interface & show controllers e1 counter on the neighboring router. Please do a clear counter before doing anything.
Subeh
Subeh Sharma
Please provide the following information
- Are you pinging 10.29.3.2 from this router or you're pinging something else?
- paste the output of the following before and after ping:
     - show interface serial 1/1/0:0
     - show controller t1 1/1/0:0
- Try pinging the other side of the link? what's the result?
Subeh
Good day Subeh-
I'm consoled into the 3845 and trying to the ping the IP that I assigned to int s 1/1/0:0 which is 10.3.29.2. It sometimes pings with packet loss and something doesn't ping at all. I can ping the other side of the link successfully with no packet loss.
Before ping:
sh int serial 1/1/0:0
Serial1/1/0:0 is up, line protocol is up
  Hardware is DSCC4 Serial
  Internet address is 10.3.29.2/24
  MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:06, output 00:00:08, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
     19152 packets input, 1319861 bytes, 0 no buffer
     Received 410 broadcasts, 0 runts, 1 giants, 0 throttles
     26 input errors, 15 CRC, 11 frame, 0 overrun, 0 ignored, 0 abort
     19170 packets output, 1318993 bytes, 0 underruns
     0 output errors, 0 collisions, 36 interface resets
     3 carrier transitions
  Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
After ping:
sh int s 1/1/0:0
  Last input 00:00:05, output 00:00:07, output hang never
     19175 packets input, 1321523 bytes, 0 no buffer
     Received 427 broadcasts, 0 runts, 1 giants, 0 throttles
     19191 packets output, 1320497 bytes, 0 underruns
Before Ping:
sh controller T1 1/1/0
T1 1/1/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  Description: T1 to LASVEGAS
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20050620, FPGA: 16, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
   Current port master clock: local osc on this network module
  Data in current interval (477 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     477 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     477 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
     900 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     900 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
     1 Line Code Violations, 2676 Path Code Violations
     755 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     753 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 145 Unavail Secs
  Data in Interval 5:
     348 Line Code Violations, 1080 Path Code Violations
     527 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     527 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 373 Unavail Secs
  Data in Interval 6:
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
  Total Data (last 6 15 minute intervals):
     349 Line Code Violations, 3756 Path Code Violations,
     3982 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     3980 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 1418 Unavail Secs
After Ping:
T1 1/1/0 is up.
  No alarms detected.
  Data in current interval (593 seconds elapsed):
     593 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     593 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
  Data in Interval 5:
  Data in Interval 6:
Subeh
Thanks for the advice Subeh!
UPDATE:
I enabled encapsulation PPP on all serial interfaces in the test lab and now I'm not dropping any pings to any of them.
int s [serial interface] in my case it was 1/1/0:0
encapsulation ppp
