Routing thru l2 switch
cisco-blue
hi all,
i have my Routers two interface configured on vlan 200 ip 10.80.8.2,
which are connected to me 3400  ,
inturn connected to a switch ip 192.168.1.35&then to server 192.168.1.201
i have tried giving routes for 192.168.1.35,192.168.1.0 coldnt get on
Ganesh Hariharan
Is there a default route is configured in switch toward the router if not just configured a default route towards the router intreface and check.
Hope the helps out your query !!
Ganesh.H
Giuseppe Larosa
Hello Cisco_blue,
or  the routers or the ME 3400 need to have a layer 3 interface in IP subnet 192.168.1.0, that  IP address can become the next-hop for default gateway on server and L2 switch. It is not enough to have a physical connection between L2 switch and the other devices.
Hope to help
Giuseppe
