RPF in multicast
wfqk
Level 5
Level 5
Four routers are connected as circle like this: A ---- B ----C ----D, and A is connected to D. So each router has the same distance cost to other. When multicast packet goes from A to C, it will have the same cost to C through B or D. My question is which interface is RPF of C? In other word, C should receive packet from B or D, or both? Thanks
2 Accepted Solutions
Jaderson Pessoa
Hello guy,
Look the exemple below:
Related link: https://www.fir3net.com/Networking/Protocols/what-is-multicast-reverse-path-forwarding-rpf.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
General Rule 2 - The RPF interface is computed as the interface with the lowest cost path (based on admin distance/metric) to the IP address of the source (or in the case of a sparse-mode (*,G) entry, the RP). If multiple interfaces have the same cost, the interface with the highest IP address is chosen as the tiebreaker.
Jaderson Pessoa
5 Replies 5
Jaderson Pessoa
Hello guy,
Jaderson Pessoa
Thank you for your fast reply. the below picture is from your link. Here is my question: when the cost is lower through R2 than R3, the routes go from R2, and gi0/1 is RPF. but when the cost is same at R2 and R4, the routes will have balance. that means the two interface gi0/1 and gi0/2 at R4 get the routes. If this is case, which interface is RPF?
Jaderson Pessoa
Great thank you!
