RPKI Validator Server Configuration
onibala
Level 2
Level 2
Can IOS, IOS-XE, or IOS-XR support server functioning as RPKI Validator? This is similar of PKI CA server configuration in any IOS platform.
I want to test it in our Lab without connecting to any RPKI servers in the Internet.
Audie
3 Accepted Solutions
M02@rt37
Hello @onibala
IOS-XE XR Ok. A doubt about IOS.... because you have a peering with ISP and have the full table.... you need plateform with IOS-XR or XE. Thens it is ok!
Best regards
Hi @onibala ,
The validator function is normally run on a separate Linux server. As far as I know, XR and XE do not support the RPKI Validator (or equivalent) functionality natively, but they both allow you to run 3rd party applications in a container. This might be an option, but I think the safest implementation would be to run it on a separate Linux server.
28 Replies 28
balaji.bandi
check below (is that works ?)
https://community.cisco.com/t5/security-knowledge-base/building-an-ios-xe-offline-root-and-subordinate-certificate/ta-p/4538753
BB
onibala
Level 2
Level 2
Thanks for the quick response Balaji! This config is for VPN certificate. I am looking for securing BGP Prefix and AS exchange.
Here are examples:
How to Install an RPKI Validator | RIPE Labs
https://rpki.readthedocs.io/en/latest/
got you, IOS XE and XR support that features as per the document.
setting offline RPKI Server (not that i have done before)
BB
Balaji,
Please provide the link of how to setup RPKI server.
Thanks!
@onibala
Refer here
xr: https://beufa.net/fr/blog/rpki-use-routinator-rtr-cache-validator-cisco-ios-xr/
xe: https://www.rheintal-ix.net/tech/rpki/
Best regards
M02@rt37
Hello @onibala
Best regards
Thanks for replying M02@rt37
I will get the XR or XE as long it can function as RPKI server.
M02@rt37,
I knew already the link given (https://beufa.net/blog/rpki-use-routinator-rtr-cache-validator-cisco-ios-xr/). I will accept it as solution, but I was looking an article from Cisco.com.
Thank You
onibala
Level 2
Level 2
Anyone has the solution from Cisco.com, and "other than" from beufa.net?
I have seen this link before. Has anyone tried it?
What you need exactly' you want to try it in lab?
MHM Cisco World,
I want to setup simple setup of 5 (IOS, IOS-XE) routers, with one functioning as the Validator. I am hesitant to buy an XR router functioning as the Validator, and does not work! I have not found an article by Cisco to back it up.
I want to see proof by Cisco that the XR can support the Validator function.
Hi @onibala ,
This is what I suspected Harold. I hope you are wrong though. That is why I was skeptical of the beufa.net article.
Thanks!
