RPL in IOS XR
simapiroh
Dear Sir/Madam
Recently Google just deployed Google Cach Server (LGC) in my network and peering to reduce traffic and fast respond to end users.
but my config seem not work fine, that's why most traffic still go to Internation instead go to Google Cach.
Below is my existing configuration and pls correct it as i want all traffic to Google/Youtube direct to Google Cach first, if not cached then go to Interational.
Pls advise
1/ Configuration to Google Cach
route-policy rp_bgp_GGC_in
  if destination in pfs_customer then
    pass
  endif
  end-policy
route-policy rp_bgp_GGC_out
  if destination in pfs_GGC_permit then
    pass
  endif
  end-policy
neighbor 123.108.253.16
  remote-as 65535
    session-open-mode passive-only
  address-family ipv4 unicast
   route-policy rp_bgp_GGC_in in
   route-policy rp_bgp_GGC_out out
   soft-reconfiguration inbound always
prefix-set pfs_GGC_permit
  # ----- NEOCOMISP Prefix -----
  x,x.x.0/24,
  x,x.x.0/24,
  x.x.x.0/24,
  x.x.x.0/24,
  x.x.x.0/24
  end-set
2/Configuration to Google Internation
as-path-set aps_google_in
  ios-regex '^(15169_)+$',
  ios-regex '^(15169_)+(36561_)+$',
  ios-regex '^(15169_)+(26910_)+$',
  ios-regex '^(15169_)+(6432_)+$',
  ios-regex '^(15169_)+(22577_)+$',
  ios-regex '^(15169_)+(36492_)+$'
  end-set
route-policy rp_bgp_google_in
  if destination in (0.0.0.0/0 le 24) then
    pass
  endif
  end-policy
route-policy rp_bgp_google_out
    pass
  endif
  end-policy
prefix-set pfs_customer
  x.x.248.0/24,
  x.x.249.0/24,
  x.x.250.0/24,
  x.x.251.0/24
  end-set
neighbor x.x.x.6
  remote-as 15169
  description ## Google BGP Peering ##
   route-policy rp_bgp_google_in in
   maximum-prefix 525000 90
   route-policy rp_bgp_google_out out
   default-originate
   remove-private-AS
Hi Sim,
I guess the policy should be the same but applied to in and out direction.
As I read you did two different policies, one for each direction.
Hope this helps
Alessio
