RPSAN VLAN
Muhammed AKYUZ
we have 6500 and 4000 switches connected each other trunk, all vlans allowed on that connection.  We are using rspan from various source ports and on both 6500 and 4000 there is one destionation.
source remote vlan 800
destination interface g1/1
When i observe the interface utulizations,  on 6500 g1/1 interface utulization is more than 4000 switch  g1/1..
What should be the difference?
  Thank you...
Kevin Dorrell
Level 10
Level 10
Can you show us the utilization figures?  Which direction are we talking about?  I assume you are comparing the output utilization of one switch with the input utilization of the other?  Please can you post the show interface so we can compare them.
Also, please check that VLAN 800 was declared as an RSPAN VLAN?
Kevin Dorrell
Luxembourg
