RSP720 throwing "Unable to locate DDR I or DDR II module" error after reset from ROMmon mode
Our one of C7609-S routers got crashed and stuck in ROMmon mode. We tried resetting RSP720 but giving the error of DDR SDRAM not found. An error of "Software Forced Crash" also visible on the screen. The router is running with 12.2(33) SRE8 IOS version. What could be the possible reason of this behavior and the next remediation action?
rommon 12 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 13 > reset
Resetting .......
System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C7600-RSP720/SP platform with 1048576 Kbytes of main memory
Autoboot executing command: "boot bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRE8.bin"
Initializing ATA monitor library...
Self extracting the image... [OK]
Self decompressing the image : ############################################################################################################################################################################################################################################################################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, c7600rsp72043_sp Software (c7600rsp72043_sp-ADVIPSERVICESK9-M), Version 12.2(33)SRE8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 18-Mar-13 12:36 by prod_rel_team
*Aug  6 03:46:04.963: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Aug  6 03:46:02.631: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
*Aug  6 03:46:04.963: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
I2C bus busy, please check the DDR SDRAM dimm slot 0
Unable to locate DDR I or DDR II module.
Can not initialize DDR SDRAM, ROMMON stop!
*Aug  6 03:49:06.107: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Aug  6 03:46:05.279: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 08-Dec-11 14:58 by integ Build [100]
*Aug  6 03:49:06.107: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
%Software-forced reload
 03:49:06 UTC Wed Aug 6 2014: Unexpected exception to CPU: vector 1500, PC = 0x835BE40 , LR = 0x835BE04
-Traceback= 0x835BE40 0x835BE04 0x8C6D89C 0x8C6EAC0 0x8C6EC2C 0x8C2CC4C 0x8C27BFC 0x835D9F8 0x8357C9C
CPU Register Context:
MSR = 0x00029200  CR  = 0x40000042  CTR = 0x08E6BF6C  XER   = 0x00000000
R0  = 0x0835BE04  R1  = 0x064BE320  R2  = 0xFFFCFFFC  R3    = 0x0FC056CC
R4  = 0x09F07129  R5  = 0xFFFFFFFF  R6  = 0x0000004C  R7    = 0x0649B5D4
R8  = 0x66666667  R9  = 0x00000000  R10 = 0x9373E4B0  R11   = 0x0D21BCD8
R12 = 0x0002E1C4  R13 = 0x04044000  R14 = 0x08C27AD0  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23   = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00000000  R27   = 0x00000000
R28 = 0x00000003  R29 = 0x064BE340  R30 = 0x0E11D540  R31   = 0x00000000
968 Unused bytes of context save space
Did you get a solution for this issue. Please confirm as i'm facing same issue in one of the device.
Create a new thread.
Plug a console in and reboot the supervisor card.  Post the entire boot-up process.  We want to see what is going on.
New thread has been created and logs are posted. Please check and help.
https://supportforums.cisco.com/discussion/13293261/rsp720-throwing-unable-locate-ddr-i-or-ddr-ii-module-can-not-initialize-ddr
