RTR configuration assistance required...
aditya deshmukh
We want to configure RTR in our network ,having a Cisco 6506 core Switch & 50 Cisco 2960 Switches. As per the ios on the 6506 the rtr command is supported not the ip sla , so we want to configure it on it.
The RTR configuration on the Source device (Cisco 6506 Sw) can be done through the below commands :
1)          enable
2)          configure terminal
3)           rtr   <Entry number>
4)          type echo protocol ipIcmpEcho <Hostname or A.B.C.D  IP address or hostname>  source-ipaddr < IP address >
5)          frequency seconds
6)          exit
7)          rtr schedule entry-number [life {forever | seconds}] [start-time {hh:mm[:ss] [month day | day month] | pending | now | afterhh:mm:ss] [ageout seconds] [recurring]
8)          exit
RTR configuration on the target devices (Cisco 2950  SW )will be :
1)          enable
3)          rtr responder
4)          exit
The query here is that :
1) Is this configuration will work ?
2) And for every Cisco 2950 Switch , i have to create  seprate rtr entry on Cisco 6506 Sw for example for 50 target device i have to create 50 entries on source device 6506 ?
Thanks in advance....
Aditya
Giuseppe Larosa
Hello Aditya,
2)  yes you need to configure  one rtr object for each target device, because you cannot mix the  results of one probe with another one.
1)  configuration looks like correct
Hope to help
Giuseppe
