RTR question
welcomeccie
int fa0/0
standby 1 track 50 decrement 10
standby 1 track 51 decrement 10
track 50 rtr 50
track 51 rtr 50 reachability
rtr 50
type echo protocol ipIcmpEcho 1.1.1.1
request-data-size 100
timeout 1000
threshold 1000
frequency 2
rtr schedule 50 life forever start-time now
can anyone tell me what is the difference between the track 50,51 with and without reachability?
and what is the parameters timeout,frequency and threshold mean?
mohammedmahmoud
Level 11
Level 11
The below link contains all the details regarding IP SLA parameters you are asking about:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsla_c/hsicmp.htm
NOTE: In Cisco IOS Release 12.3(14)T, the Cisco IOS Service Assurance Agent (SAA) feature was replaced by the Cisco IOS IP Service Level Agreement (IP SLA), accordingly the "rtr" command was replaced by the "ip sla monitor" command.
As for the reachability keyword with the track command, when configuring enhanced tracking you can use either state (the default) or reachability.
Router(config)#track 1 rtr 1 ?
reachability Reachability
state Return code state
The difference between these states relates to the acceptance of the OverThreshold return code, i always use reachability as the OverThreshold is most commonly not an issue, please check this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d2d74.html#wp1048088
HTH,
Mohammed Mahmoud.
