10-17-2015 12:28 PM - edited 03-05-2019 02:31 AM
For the RV082 this router have two wan interfaces so can i aggregate the bandwidth between two ISP connection or i can only make load balancing between them ?
Solved! Go to Solution.
10-17-2015 07:54 PM
You can not aggregate two WAN links to different ISPs. You can either use load balancing across both links or failover.
10-17-2015 07:54 PM
