08-11-2018 11:26 AM
Hi all,
I have a Cicso RV042G VPN router that will have a PBX gateway device (Citel MCK) connecting Nortel Meridian phone lines through to an Extender device (Citel MCK) behind another Cicso RV042G VPN router. I am having difficulties setting up the communications. This setup did work when there was no router involved (using the ISP modems on each end). I am curious if this model of router is capable of handling phone traffic.
dlangschied
08-11-2018 12:00 PM
basically, voice traffic is just IP traffic, it shouldn't really matter what you send over the VPN. Do you have physical and logical connectivity between the PBX and the local RV042G ?
The attached admin guide (see page 186) gives an example on how to set up bandwidth management for VoIP...
08-11-2018 03:52 PM
Thank you for the document. I had a similar document from Citel MCK, but this was better as it related directly to the router.
With the setup completed, I still have my issue. I am not sure where to turn. Citel people are telling me it is the Cisco router, but I don't see it. Their only test is to ping the router. I do not have ICMP allowed, I was not about to allow access through that port. I did disable the firewall for a few minutes, but I couldn't ping. I am not sure about why that is so unless the ISP modem is not allowing it. I won;t be able to check that until Monday.
