RV082 or other low cost Cisco router recommendation
dvnizr189
My name is David.  I currently run a small 52 people BPO and we are soon moving a to a larger 350 people capacity.  I wonder if someone comment on the following:
-  We currently use DLink routers, which are quite limiting in terms of features.  We are considering going Cisco but some of the routers are very very expensive.  I was wondering if RV082 series router would support 350 people on the LAN.  It does have paid subscription to content filtering, QoS, dual WAN with failoever/load balancing.  It does not have bandwidth monitoring/control on each LAN user connected - thats the only limiting feature I feel from our current usage/features we are looking for.
Would really love to hear your views on this.
Thanks in anticipation,
David
Regarding your question, RV082 is not capable of support 350 people on the lan because supports up to 50; In that case I would recommend you a different model.
and regarding the bandwidth, you could control and set it using the instructions on the next link
http://www6.nohold.net/Cisco2/GetArticle.aspx?docid=3c09b393e3744ffd98330fd0031a4aa2_4228.xml&pid=80&converted=0
And for the monitoring you would need to install a different software, Let me give you the links of a couple of examples.
http://www.paessler.com/prtg/?source=adwords&campaign=prtg_Latin_Search_English&adgroup=bandwidth_monitor&adnum=002&gclid=CIDt84fExLICFcXb4AodgAIATA
http://www.sonic.net/wallwatcher/
http://oss.oetiker.ch/mrtg/
