Hello everyone!
Having some very strange issues recently with our setup here. Let me hash out the details.
We have two locations, in our remote location, an RV082 and at our main branch, SW2040. Current setup has been in place and GREAT for years! Just yesterday though the VPN has dropped considerably, and refueses to stay up for more than a few minutes at a time - then I have to rehash the connection manually in the RV, but cannot within the SW. When this happens I also lose internet on the LAN.
I had called the broadband provider and verified connectivity to the router.
Using a GW to GW VPN...
Jun 2 14:14:14 2010 | VPN Log | Ignoring Vendor ID payload Type = [draft-ietf-ipsec-nat-t-ike-00] |
Jun 2 14:14:14 2010 | VPN Log | [Tunnel Negotiation Info] <<< Responder Received Main Mode 1st packet |
Jun 2 14:14:14 2010 | VPN Log | (NATT)Initial Main Mode message received on REMOTE IP:500 but no connection has been authorized. Please check your tunnel endpoint (gateway) setting |
Jun 2 14:14:14 2010 | VPN Log | Dynamic VPN client in Main Mode is only supported for Microsoft VPN client, please use Aggressive mode instead. |
RV082 Settings...
IP ONLY Subnet based
IKE with preshared key
Phase1 - Group1/DES/MD5/28800 seconds
no PF secrecy
Phase2 - DES/MD5/3600
Aggressive mode is not checked
Keep-Alive is checked
NetBIOS broadcast is checked
SW2040 Settings...
IKE using preshared key
Main Mode
no PF secrecy
Phase2 - ESP protocol/DES/MD5/3600
Keep Alive enabled
Try to bring up all possible Tunnels Enabled
So this is what I have. I would really appreciate some help to save me a trip across the country
Thanks!
