Switch Port Trunk
soofiahtesham
Hello All,
I having a interface which is configured right now as
interface gigabitethernet x/x/x
swicthport acess vlan xx
swicthport mode  acess
spanning - tree portfast
And I want it to change to the following
swicthport trunk encapsulation dot1q
swicthport  trunk native vlan xx ( same vlan number as above )
swicthport mode  trunk
speed 1000
duplex full
  • Commands to make the changes
  • Is there anyway to copy the configuration from a interface which is running a similar
Thanks in advance
Soofi,
Leo Laohoo
Try the following method:
default interface Gig a/b/c
interface Gig a/b/c
copy-n-paste the commands.
10 Replies 10
Leo Laohoo
interface Gig a/b/c
Copy and paste which commands ?
These:
speed 1000
duplex full
Thanks seems like it worked. however I got this error message is it some thing critical ?
%Warning: portfast should only be enabled on ports connected to a single
host. Connecting hubs, concentrators, switches, bridges, etc... to this
interface  when portfast is enabled, can cause temporary bridging loops.
Use with CAUTION
%Portfast has been configured on GigabitEthernetx/x/x but will only
have effect when the interface is in a non-trunking mode.
Since this is trunk port you need to turn off portfast
no spanning - tree portfast
Reza
Hi Reza.
Thanks for the reply... It is connected to hpyer v terminal and it is Dell who has recomended the port fast.. Even thoug  it is not recomemended by Cisco.
I have another issue ...
Even Thought the above mentioned port is been trunkated for some reason  I am still unable to talk to other VLAN that includes the default  VLAN on the swicth.
-> Command to check as to which VLANs are allowed on a certain PORT
->  How to add a specific VLAN on certain PORTS.
-> Or any better suggestion are welcomed
Soofi
AhteshamSoofi@Deeley.com
Hi Reza.
Soofi
Hi Soofi,
Do a "show vlan" or "sh spanning-tree vlan x" to see the ports in a specific vlan.
You don't add vlans to ports.  You add physical ports to vlans.
You should not run portfast if you are connecting to another switch.  Portfast is for end user PCs, printer,etc,....
Reza
Leo Laohoo
Don't forget to rate useful posts.  Thanks.
Soofi
show vlan [brief] will show you which ports are assigned to which VLANs.
show interface trunk will show you which ports are configured as trunk and what VLANs are allowed on the trunk (among the outputs).
