RV130 firewall diagnostic
Zsolt Kendi
Dear Everybody!
How it possible to query the firewall blocked A:P->A:P connections on RV130?
We use RV130 for sensor network as firewall.
This mean continuous and high (small packet) traffic on many TCP connection.
During sometimes the firewall block TCP connections A:P->A:P with any known reason.
In this case all other connection are works fine.
If happened then we have no any log or diagnostic message.
To repair it only way to switch off the RV and on again.
If we switch off IP address spoofing and DoS protection a situation are same.
Thanks for any advise: kzsolt
Georg Pauwen
what is the exact log/error message you are getting ? And what do you mean by A:P ?
First of all, make sure you run the latest firmware release (version 1.0.3.55, attached).
Zsolt Kendi
"what is the exact log/error message you are getting ?"
"If happened then we have no any log or diagnostic message."
"And what do you mean by A:P ?"
The TCP/IP communication identified by A:P -> A:P.
This mean the TCP connection initiated on IP address A on port P,
 and estabilished to -> IP address A on port P.
