RV260W: Console port - Assign to lan possible?
moheban79
Have an RV260W and need one more open port for networking connections as all 8 ports on the back are all occupied. Anyhow I notice there is a console port that looks like an ethernet port and was wondering if the firmware allows that port be assigned to lan giving you 9 ports??
Hello
The console port cannot be used as an additional Ethernet port, its used only for direct management access to the device
Kind Regards
Paul
Hello
Kind Regards
Paul
Ok. Thanks.
Looks like I need a switch..
luis_cordova
Hi @moheban79
As @paul driver  indicates, the console port cannot be used as an ethernet port. I think you have two options:
1 Check if a device that is already connected can be connected via Wi-Fi, as that would free up a port. 2 Get a switch to extend the available ports.
Thanks. Wifi not secure. Will install a switch I already own when time comes.
