RV320 and IPTV
Ku_Multiperson
Hi.
I have a RV320 router with ISP Ethernet chord plugged to WAN port. This chord is using for Internet and IPTV. An IP address is assigned by ISP's DHCP server. My IPTV box is plugged to LAN4 port which is binded to separate VLAN. IPTV box takes the IP address from RV320 in this VLAN it get TV shchedule, screens and archive from IPTV server, but it doesn't show streaming TV. I have enabled multicast pass-through of course. When I installed switch before RV320 and plug chord from ISP, IPTV box, and RV320 WAN into it everything works perfectly. What's going on wrong? I don't want to have unnecessary device before RV320.
Any suggestions?
Also maybe someone can tell me if enabled multicast pass-trough cover all ports on RV320 device? On old models (like RV125) there were possibility to assign IGMP Proxy to separate ports in Advanced Firewall menu.
0 Replies 0
