RV320 Protocol Binding - Bind Traffic to Specific Destination
sdorn9999
I have the Cisco RV320 load balancing router.  WAN 1 is a Comcast cable modem at 105Mbps down and 20Mbps up.  WAN 2 is AT&T U-Verse line at 18Mbps down and 1.5Mbps up.  I
I also have U-Verse television service, and need to have all traffic originating on my network that is going to any AT&T related website (mainly AT&T.com, AT&T.net and Uverse.com) as well as any traffic on the U-Verse apps on my phones, tablets, etc. to all go over WAN 2.  All other traffic generally needs to go over WAN 1.
I have successfully used the Protocol Binding settings to bind traffic from a specific Source IP address to the WAN port I choose, and it works fine.  However, when I try and specify a specific Destination IP address (such as setting all traffic with a destination of 63.241.233.81 to use WAN 2, which should route all traffic to uverse.com over WAN 2), it doesn't work.  Nothing happens.  The traffic just continues to go over WAN 1, even if I set that rule as the highest priority on the protocol binding table.
Any ideas?
0 Replies 0
