RV325 site to site with RV345P
ferdinando.alde
How can I change the IP address of the "local group" of an RV325?
Let me explain: the WAN1 is connected to a supplier's router and the IP is 192.168.1.4, for the VPN I need the static IP 2.xxx.xxx.164. I can not use NAT-T because the other side of the VPN (RV345P) does not have NAT-T.
Thanks for every idea or solution.
the IP address shown in the Local Group is derived from the static address you have configured under WAN Connection Settings --> WAN Connection Type --> Static IP --> Specify WAN IP Address.
That is where you can change the address.
of course. The problem is that the router is after the vendor's router and
the WAN address is not the static one of the connection. So it should be
changed for the VPN. As is possible for both RV130 and RV345.
