RV340 Failover but keeps using data
John_551
I have a Cisco RV340 router with Dual WAN setup as failover.
I've tested everything and works as it should fails over, then back.
My problem is the my secondary WAN us a USB LTE with limited data, and all the data is being used.
Is there a way to totally shut down the secondary USB WAN when the primary is operating as normal.
I've been racking my head and can't figure it out.
I have the data metering set up and I'm getting constant data limit it is up.
Any help would be great
0 Replies 0
