RV340 Firmware upgrade warning icon - 1.0.03.15
Meshur
Upgraded to 1.0.03.15 today, and since the upgrade I have a permanent flashing warning triangle on the UI.
It suggests I upgrade the firmware, which I've already done. If I attempt the upgrade again, I get a message saying I have the latest firmware (of course) the warning remains, but the message changes to "Download firmware fail, Please try again later", and remains, no combination of rebooting, saving, loading config appears to clear the warning.
Please dont tell me I need to reset the configuration to clear this warning...
I do notice on the System Information page, the Last Updated: is now N/A, rather than the time of the last update
JRodr
I had the same problem.
I noticed that if I go to Administration - Reboot, the inactive image is on the older version as is normal.
I think the router is detecting that.
I updated the firmware again, but loading the firmware file from my computer (I downloaded first from cisco website).
Go to File Management - Manual Upgrade - Select PC - Select the firmware image that you downloaded to your cumputer and click upgrade.
After the router reboots if you go to Administration - Reboot, the inactive image is the same version and the router no longer warns about the existence of a new firmware.
I hope this helps
8 Replies 8
try and reset the router to factory defaults, then follow the procedure outlined in the link below:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5506-upgrade-firmware-on-an-rv34x-series-router.html
Reset to factory defaults is exactly what I was trying to avoid, I need to set aside a day when we can do without internet to reconstruct the old config, just to clear a buggy icon. /sigh
lwp
I have this issue too. Persisted after reset and upgrade for me, but will wait to see if new update later on resolves it as I don't want to do another reset.
JRodr
I hope this helps
Thanks! This solution worked perfectly!
Great workaround, thanks, solved the issue for me also.
Glad I found this.  Worked like a champ!  Many thanks.
I ended up doing this, it did work for me as that triangle has vanished.  I do however think there are other issues.  I am currently unable to delete a client-to-site config I had previously created.  I am also unable to restore a config backup back to the running config...  There are other issues....
