RV340W Static Route to connect to networks
Smejico
Cisco Novice here and could use some help...
I just purchased 2 RV340W for each office to replace 2 GB-800e routers at our 2 offices.  We currently have Telepacific 1 NET MPLS which connects the 2 offices.  Currently both GB-800e's have static routes that enable both networks to talk.  I see the RV340W has the capability of static routes would anyone be able to assist on how to configure this?
Current networks are:
network 1 - 10.0.0.x
gateway 1 - 10.0.0.2
network 1 MPLS device - 10.0.0.2
network 2 - 192.168.0.x
gateway 2 - 192.168.0.1
network 2 MPLS device - 192.168.0.2
Current Static routes look like
Static route 1
Network 192.168.0.0/24
Gateway 10.0.0.2
static route 2 -
Network 10.0.0.0/24
Gateway - 192.168.0.2
How do i set these up on the cisco RV340W's and is a access rule needed along with these routes for traffic to flow successfully?
Giuseppe Larosa
Hello Smejico,
for configuring static routes on your device follow the instruction on page 71 of the following guide
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/Administration/EN/b_RV340x_AG.pdf
You should not need special rules to allow traffic to travel over the links unless you have enabled also firewall features.
For firewall features in the same document go to pag. 73
Hope to help
Giuseppe
