RV345 IPSec Passthrough from WAN via NAT to a internal Destination-IP
timo.woellner1
Hello !
I would like to set up an extended route that allows me to set up a specific destination IP address with NAT from a special source IP address including all RV345's own services, including IPSEC VPN.
8 Replies 8
pman
timo.woellner1
thank you, but that was not my intention. I know very well how to configure an IPSEC VPN tunnel between two RV345 or other remote stations. The point is to configure an additional VPN tunnel behind the RV345 on a different firewall.
pman
So basically you want to create another VPN profile to new remote WAN IP and what will go through is another Local IP address (on RV345)?
if I got it right, then yes
here again:
I would like to forward a specific remote address incoming over a wan interface completely to an internal address at another firewall in a vlan on the RV345 including all ports and protocols. For IPSEC-VPN these are at least the ports 500udp, 4500udp and the ESP protocol.
i think that if you need a specific remote address incoming over a wan interface to get to a specific internal address behind the RV345 at certain ports then what you need is port-forwording + access-rule.
There may be another way to do this, maybe someone else will be able to give his advice
port-forwording
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5818-configure-port-forwarding-port-triggering-nat-on-rv34x-serie.html
access-rule
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5491-configure-access-rules-on-an-rv34x-series-router.html
thanks, i will test it tomorrow.
Can you tell me in which order the access rules and port forwarding and perhaps the other security functions are processed?
OK. I have tested.
Access Rule:
WAN1 from the specified remote ip address to the specified destination IP address in vlan 1 behind the RV345 with any traffic and any services, only work for services that do not run on the RV345 itself.
and now ?
OK. I have tested.
Access Rule:
and now ?
