RV345 Port Forwarding Table unable to update
Java_user
I have configured one RV345 some time ago. Now I want to add one more rule for a forwarding port. I have already 7 port forwarding rules working and I wanto to add one more. I have created the service management and the access rules are ok. When I add the port, service and IP configuration in the forwarding table and click on Apply button, the message success appears, but the table comes back again to the previous one and nothing changes. I also try to delete one row but it happens the same, nothing changes. What is happenning? Why I can not change/update the table? I have administrator rights.
Thank you.
Mark Elsen
 - Make sure to run the latest firmware version, then try again.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Which firmware you are running, if you have another device running an upgraded firmware version then test that device.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
