Saving, copying Config files using usbflash in 3750 switch
jaydenle
Hi All,
I am having difficulties saving, loading conifg files from a USB, can anyone please tell me what is the correct command for loading a config file from USB for cisco 3750x switch. Thanks for your help.
Leo Laohoo
If your USB stick is supported and correctly formatted, the command should be "copy usbflash0:filename.txt run".
