SCE 8000 error in software/hardware
I have a 8000 and the Device SCE   8000 turn it. single handle these messages: The computer is damaged. Levato must be an RMA, or the problem is hardware or software.
Any idea??????
548  OK delta time : 6090 msec
Connecting RpcClient 'RPC[08]_PPC[04]_CORE[01]' to IP '192.168.207.149', port 2549  OK delta time : 3 msec
Connecting RpcClient 'RPC[09]_PPC[05]_CORE[00]' to IP '192.168.207.150', port 2548  OK delta time : 3 msec
Connecting RpcClient 'RPC[10]_PPC[05]_CORE[01]' to IP '192.168.207.150', port 2549  OK delta time : 3 msec
Connecting RpcClient 'RPC[11]_PPC[06]_CORE[00]' to IP '192.168.207.151', port 2548  OK delta time : 3 msec
Connecting RpcClient 'RPC[12]_PPC[06]_CORE[01]' to IP '192.168.207.151', port 2549  OK delta time : 3 msec
RPC servers for master 0
Nala boot - Optical bypass on boot activated = True
Nala boot - Power Up detected setting bypass between LICs mode
NJC ISP upgrade procedure version 1.0.0
NJCPLD: actual version 0x9274 legal version ranges: accept-ranges = { [0x9274,0x9274] }, deny-ranges = { }  match-check: up  result: match
No need to upgrade NJC version is up to date
create njc max1668 device
create njc summit766 devices
Detected Bay Constellation:
SPABay[0] - 10G  SPABay[1] - 10G  SPABay[2] - 10G  SPABay[3] - 10G
Detected platform type: 10G
Nala eeprom create OK
Nala eeprom read OK
try to program dpt fpga from file : 'fpga/dpt_nala_s130.rbf'
Force diag DPT program = True
Forcing Nala DPT configuration
program Nala DPT 0  fpga/dpt_nala_s130.rbf
njc dpt 0 program ok
program Nala DPT 1  fpga/dpt_nala_s130.rbf
njc dpt 1 program ok
NalaDPT DPT SCOS mode force to queue to 64MB
NalaDPT queue size is 64MB
SimbaDPTDmx interrupts callback registration succeded
SimbaDPTMux interrupts callback registration succeded
DSR is supported
DSR MIP exists
DPTDsr. init MIP all units. enable:1
DSR is supported
DSR MIP exists
Powering on Spa
Powering on Spa
Powering on Spa
Powering on Spa
Creating SPA c2w
Allocating SPA mutex
Retraining SPI4.2 channel on SPA bay 1!
Creating SPA c2w
Retraining SPI4.2 channel on SPA bay 0!
SPA Bay 1: first init phase passed
SPA Bay 0: first init phase passed
Creating SPA c2w
Retraining SPI4.2 channel on SPA bay 2!
SPA Bay 2: first init phase passed
Creating SPA c2w
Retraining SPI4.2 channel on SPA bay 3!
SPA Bay 3: first init phase passed
SPA Bay 1: Starting init phase 2
SPA Bay 0: Starting init phase 2
SPA Bay 2: Starting init phase 2
SPA Bay 3: Starting init phase 2
SPA Bay 1: Starting init phase 3
SPA Bay 0: Starting init phase 3
SPA Bay 2: Starting init phase 3
SPA Bay 0: Starting init phase 4
SPA Bay 3: Starting init phase 3
SPA Bay 1: Starting init phase 4
SPA Bay 2: Starting init phase 4
SPA Bay 3: Starting init phase 4
SPA Bay 0: SPA init passed
SPA module in SPA bay 0 was found and initialized!
SPA Bay 1: SPA init passed
SPA module in SPA bay 1 was found and initialized!
SPA Bay 2: SPA init passed
SPA module in SPA bay 2 was found and initialized!
SPA Bay 3: SPA init passed
SPA module in SPA bay 3 was found and initialized!
Num of ports = 4
Setting system to bypass between LICs mode!
Process affinity succesffuly set to cpu 1.
NalaPortManager: EnableAllPorts to 1 Now!
NalaPortManager: Set Enable to 1 Port TenGigabitEthernet0/0[0].
NalaPortManager: Set Enable to 1 Port TenGigabitEthernet1/0[0].
NalaPortManager: Set Enable to 1 Port TenGigabitEthernet2/0[0].
NalaPortManager: Set Enable to 1 Port TenGigabitEthernet3/0[0].
Tavor with SMC
Cofico 0 : present
Cofico 1 : present
create tavor-max1668 device
create smc_max device
create cofico 0 smc_pm i2c bus :  OK
create cofico 1 smc_pm i2c bus :  OK
tavor workaround !!
Init cofico 0 smc_pm i2c bus :  OK
Init cofico 1 smc_pm i2c bus :  OK
Smc eeprom create OK
Smc eeprom read OK
Create cofico i2c bus 0 devices
cofico 0 => board type: P2
Create cofico i2c bus 1 devices
cofico 1 => board type: P2
create cofico i2c bus 0 devices
create cofico i2c bus 1 devices
create tavor-max6681 device
DPT file name fpga/dpt_smc_s180.rbf
program DPT fpga/dpt_smc_s180.rbf
dpt program ok
program CLS  fpga/cls_top.rbf
cls program ok
SimbaPlatformMasterComponentManagerBase devices init OK
Create chassis component manager
All Cofico cores pass stage 0  succesfuly ( program FC )
SimbaPlatformMasterComponentManager::Create
TSEC memory check okay (required=6242367, we have 6291456)  !
Tavor TSEC Created !
CLS version :0x2112
Initializing Backplane LinkManager component
Cls metering init done !
Cls main component - PLLs connecting to DPT locked !
InitSRAMMemory, polling ok after 1 loops
Check CAM InitStaticRegion
CAM - Init done !
CLS init SDRAM - waited 44 loops
Cls interrupts callback registration succeded
Cls main - init OK !
SMC DPT SCOS mode force to set queue to 64MB
SimbaDPT queue size is 64MB
SetNewTxCountersSupported(1)
SimbaDPTClsIf interrupts callback registration succeded
DPT  interrupts was masked successfully
All Cofico cores pass stage 2  succesfuly (Init Components core:1)
All Cofico cores pass stage 2  succesfuly (Init Components core:0)
HWSRV_DP_Init  OK
Simba is inserted in slot 1 and link speed is 20G -> Initializing Secondary SSA link
Initializing Backplane Links
NalaDPT[0] link synced failed!!
Failed to sync DPT to DPT during try 0
SimbaDPT[0] link synced failed!!
Failed to sync DPT to DPT during try 1
Failed to sync DPT to DPT during try 2
Failed to sync DPT to DPT during try 3
read hw-monitor support info and check tree
tavor cpu temperature monitoring device support = 1
cofico 0 cpus temperature monitoring device support = 1
cofico 0 current monitoring support = 1
cofico 1 cpus temperature monitoring device support = 1
cofico 1 current monitoring support = 1
run share memory network
MprocCommon::initQueues2(): G_HSRV_GetBladeLocalProcId()=0, max_def=12.
share memory usage
m01     1536KB     1104KB  71%
s01     1024KB      544KB  53%
m02     1536KB     1232KB  80%
s02     1024KB      544KB  53%
m03     1536KB     1104KB  71%
s03     1024KB      544KB  53%
m04     1536KB     1104KB  71%
s04     1024KB      544KB  53%
m05     1536KB     1104KB  71%
s05     1024KB      544KB  53%
m06     1536KB     1104KB  71%
s06     1024KB      544KB  53%
m07     1536KB     1104KB  71%
s07     1024KB      544KB  53%
m08     1536KB     1104KB  71%
s08     1024KB      544KB  53%
m09     1536KB     1104KB  71%
s09     1024KB      544KB  53%
m10     1536KB     1104KB  71%
s10     1024KB      544KB  53%
m11     1536KB     1104KB  71%
s11     1024KB   configuring PHY 2:02  advertise:0000006F  speed:0  duplex:0
   544KB  53%
configuring PHY 2:03  advertise:0000006F  speed:0  duplex:0
m12     1536KB     1104KB  71%
s12     1024KB      544KB  53%
All queues ready.
Nala DPT support SE
Enable CLS MLIP SimbaDPT version is 491a
Ethernet kernel interface create OK
Simba card is inserted in slot 1
Nala card is inserted in slot 3
Cofico 0 is present
Cofico 1 is present
*************** W A R N I N G <start> ***********************************
TvrSmm: actual version 0xf2c1702 does not match legal version ranges: accept-ranges = { [0x10005,0x10007] [0x20000,0xffffff] [0xf2c1701,0xf2c1701] }, deny-ranges = { }
***** WARNING DESCRIPTION:                                          *****
***** some hardware versions are incompatible with this software!   *****
***** (did you manually upgrade some hardware unit?)                *****
***** NOTE #1: this is temporarily a warning (should be an error).  *****
*****          your system might work ok, but don't count on it.    *****
***** NOTE #2: error messages above and below this warning block    *****
*****          are not necessarily (and mostly are not) related     *****
*****          directly to this warning. if Hw init fails, you      *****
*****          should see an ERROR prompt indicating it.            *****
*************** W A R N I N G <end> *************************************
HW Init finished OK
Found 0 recvQueue for collector #0, 'nsm-to-sm-high'.
Found 0 xmitQueue for dispatcher #0, 'nsm-to-sm-high'.
Found 0 recvQueue for collector #1, 'sm-to-nms-high'.
Found 0 xmitQueue for dispatcher #1, 'sm-to-nms-high'.
Found 0 recvQueue for collector #2, 'nsm-to-sm-med'.
Found 0 xmitQueue for dispatcher #2, 'nsm-to-sm-med'.
Found 0 recvQueue for collector #3, 'sm-to-nms-med'.
Found 0 xmitQueue for dispatcher #3, 'sm-to-nms-med'.
Found 0 recvQueue for collector #4, 'nsm-to-sm-low'.
Found 0 xmitQueue for dispatcher #4, 'nsm-to-sm-low'.
Found 0 recvQueue for collector #5, 'sm-to-nms-low'.
Found 0 xmitQueue for dispatcher #5, 'sm-to-nms-low'.
Found 0 recvQueue for collector #6, 'nsm-to-sm-ulow'.
Found 0 xmitQueue for dispatcher #6, 'nsm-to-sm-ulow'.
Found 0 recvQueue for collector #7, 'sm-to-nms-ulow'.
Found 0 xmitQueue for dispatcher #7, 'sm-to-nms-ulow'.
SeAppMain(): About to call readConstDbFiles(), emergency=0
Reading platform DB (emergency=0)...
Pre-setting 2 constDb variables (hard coded):
Reading conf file 'DbConst.txt' from directory '/pkg/scos', sending to slaves...
Checking for DB const file '/pkg/scos/DbConst.txt'... Found, reading it.
Reading one DB const file '/pkg/scos/DbShape.txt'...
Reading one DB const file '/pkg/scos/DbFrmtr.txt'...
Reading one DB const file '/pkg/scos/DbParty.txt'...
Reading one DB const file '/pkg/scos/DbSched.txt'...
Reading one DB const file '/pkg/scos/DbJvm.txt'...
Reading one DB const file '/pkg/scos/DbCards.txt'...
Reading one DB const file '/pkg/scos/DbCpuUtil.txt'...
Reading one DB const file '/pkg/scos/DbMem.txt'...
Reading one DB const file '/pkg/scos/DbClsCam.txt'...
Reading one DB const file '/pkg/scos/DbRpc.txt'...
Reading one DB const file '/pkg/scos/DbSanity.txt'...
Reading one DB const file '/pkg/scos/DbNrmFac.txt'...
Reading one DB const file '/pkg/scos/DbBox.txt'...
Reading one DB const file '/pkg/scos/DbMisc.txt'...
Reading one DB const file '/pkg/scos/DbM2Sys.txt'...
Reading one DB const file '/pkg/scos/DbOpenOnN.txt'...
Reading conf file 'DbConst.txt' from directory '/pkg/scos/Rev=A', sending to slaves...
Checking for DB const file '/pkg/scos/Rev=A/DbConst.txt'... Does not exist.
Open user defined const db file /apps/data/scos/system/usrconst.txt for read
Config file '/apps/data/scos/system/config.txt' not found, not extracting 'debug const-db' commands from it.
Sending const-db END command to slaves...
DbConstFileReader::readMainFile(): Sending end command 'END' to slaves after sending 164 vars, took 5992 sys ticks.
processSeCommonConstDbInterfaceSpecificParams(): ifType=3, our data=10000000, no need to change queue params.
2073 DB variables initialized out of 2073.
Checking if pstack supported
shell_runner(): beginning shell.
shell_runner(): Initializing minishell server on port 78 (78 + 0).
Starting minishell server on port 78.
Minishell server started OK.
SCOS shell was created - task ID = -1880984416
SCOS shell started for the first time
pstack isn't supported in this platform
The CRASH module was started
KernelWatchdog monitor WD Statitics task was triggered
init Cpu Utilization Monitor module init succeeded
DBG 'common.CriticalSection.DBG_COULD_NOT_CREATE' hash= 4130614079.
DBG 'common.CriticalSection.DBG_LIST_FULL' hash= 585703309.
DBG 'common.CriticalSection.DBG_REMOVE_NOT_FOUND' hash= 3907609472.
DBG 'common.test.msg2' hash= 2670446627.
DBG 'common.test.msg3' hash= 3476223276.
DBG 'common.test.msgA' hash= 89862758.
DBG 'common.DbContainer.DBG_NO_MEMORY' hash= 1179297079.
DBG 'common.DbBase.DBG_ADDING' hash= 3674379735.
DBG 'common.DbBase.DBG_ADDING_OK' hash= 1198001663.
DBG 'common.DbBase.DBG_NULL_PTR' hash= 1853563718.
DBG 'common.DbBase.DBG_BAD_INDEX' hash= 1091176901.
DBG 'common.DbBase.DBG_SET_CONST' hash= 2538370734.
DBG 'common.DbBase.DBG_DUPLICATE_NAME' hash= 1287558230.
DBG 'common.DbBase.DBG_NO_MEMORY' hash= 2546497118.
Recorded 14 DBG messages, 0 hash collisions.
Initializing heap consumers...
Finished initialising heap consumers after 3 loops.
Calling DBG_Init()...
Debug queues are initialized
TT Handler init
Calling 39 DBG init functions...
Registering IPv6_Reporting DBGs...
Registering IPv6_DB DBGs...
Registering EDM DBGs...
Registering ENGAGE_TUNABLES DBGs...
Registering SUB_CONTEXT DBGs...
Registering ENGAGE_API DBGs...
Registering VLUR_REPORT DBGs...
Registering NUR DBGs...
Registering SUR DBGs...
Registering PARTY_PERIODIC_REPORTING DBGs...
Registering REPORTING_API DBGs...
Registering QE DBGs...
Registering CcPeriodicAggregatedRecords DBGs...
Registering REPORT_AGG_SUBTASK DBGs...
Registering ReportAggregationManager DBGs...
Registering ENGAGE_REPORT_AGG_LISTENER DBGs...
Registering ENGAGE_INIT_STUFF DBGs...
Registering RDR_RATE_CONTROL DBGs...
Registering PERIODIC_REPORTING DBGs...
Registering ENGAGE_REPOTING_DB DBGs...
Registering EngageDb DBGs...
Registering AppModules DBGs...
Registering LcTestApplicationLoader DBGs...
Registering TimeBasedHandlers DBGs...
Registering MCM DBGs...
Registering ManagementVariables DBGs...
Registering LineCard DBGs...
Message status cannot be set to "ALWAYS ON"
DBG_RTSetMsgPeriod: Message number 14 is larger then maximum -1 for module 0xc01
Registering LineCard2 DBGs...
Registering LinecardHandlers DBGs...
Registering VSA DBGs...
Registering ControlCard DBGs...
Registering PartyDynamicStateManager DBGs...
Registering CcAppVariableStorageManager DBGs...
Registering ControlCardHandlers DBGs...
Registering Reporting DBGs...
Registering ReaderFileSystem DBGs...
Registering SeCommon DBGs...
Registering HandlerDeclaration DBGs...
Registering Common DBGs...
DBG Rate control restored to normal state.
Setting the cascade ports definitions: 2 2 3 3 2 2 3 3 (crossed connected)
BootLog: Creature 'ControlCardInit' started.
Spawning ControlMain task...
*  Starting boot process of Cisco SCE8000 Control Card - OS Version 3.6.1 Build 13.
Not setting Control-Card affinity.
* Warning: setting recovery mode flag on !!!!!!
Setting system status to emergency due to 3 successive reboots!
Beginning Version 3.6.1 Build 13, SCE8000 Version 3.6.1 Build 13.
PartyDBManager::getMemorySize() called:
  numPIDs=1012000, partyEfficiencyFactor=400,
  numIpEntries=1000000, ipEfficiencyFactor=400,
  numRangeEntries=250000, radixEfficiencyFactor=200,
  maxVpnId=4000,
  numUnmappedRanges=5000, numUnmappedTunnels=0,
  Returning 94317564+162631780+846928=257796272.
BootLog: Creature 'LineCardInit' started.
Spawning RucMain task...
Setting Master RUC affinity to core 1...
Setting Master RUC affinity returned 0...
Line card watchdog initialized
Starting Memory Monitoring Task
Rpc client server already created
Init only link and task
MsgHndlr: Registering RUC server interfaces...
I'm a Master
In RucEmergencies::initEmergencies
In RucEmergencies::initEmergencies theEmergencyMessanger = 0x12f823c0, message queue id = 20
In RucEmergencyMessenger::createReceiverCommon
Initializing traverser Watchdog, TWD Status = 1 (0=disabled, 1=enabled), LogOnly Status = 0, sampling interval(uSec)=5000 sampling timeout(miliSec)=20000
Number Of Assembled ports 4, Number Of Supported ports 4
Port topology is set for Full port configuration - Single box
Platform type is multi CPU
CPU type is CPU_CONF_MASTER_ONLY
12 agents detected, FF configured to 12 agents
Registering RuC RPC client interfaces...
#total shell commands: 11333
master00->
Spawning Reboot Support Task
Reboot support task started
CmdlGenIf: Tables are OK, 1545 funcs found.
* Warning: Recovery mode flag is on !!!!!!
SANB_iosDevFind(): Device '~/should-not-exist' does not exist.
SANB_iosDevFind(): Added device '/apps/data/scos' because device '/apps/data/scos' contains soft-links.
Init remote ip messages
Ruc ques are initiliazed
Ruc_Init(): Init VAS HW
Ruc_Init(): PPC 0 initialized Flow-Capture Recording Rules manager successfully.
Ruc_Init(): PPC 0 - no need to initializing Flow-Capture manager.
Host name from boot is 'host_name'.
hiddenDir is '/apps/data/scos/system/p3hidden'.
systemDir is '/apps/data/scos/system'.
IP address is '0.0.0.0', subnet mask is '0.0.0.0'.
running script scos_mkdir --clean --dir /apps/data/scos/system/package/ftp , script output:
BandwidthMeterTable Created.
init hw counters manager
INFO: Waiting for Complex RPC server to finish init...
script return val is 0
running script scos_mkdir --clean --dir /apps/data/scos/system/package/extract , script output:
Watchdog task spawned - task name: tCCWatchdog
SysWatchdog scos-watchdog-monitor was disabled
SysWatchdog scos-watchdog-monitor was enabled
Initializing Control-Card FTP client...
FTP manager init succeded - local cached dir /apps/var/scos/ftp/
CLI initialization started
Boot Time Watchdog ended after 75 seconds
Registered 117 out of 224 CLI trees, found 0 trees with problems.
CLI initialization finished successfully
Activating Generic SCOS RPC server. TimeStamp:77.
Activating telnet server. TimeStamp:77.
Starting Internal Cli Server on port 2222 for use by Telnet.
Starting telnetServer server on port 2222...
Internal Cli Server started.
Telnet Server started OK.
Activating SSH server. TimeStamp:77.
Starting sshServer server on port 2223...
Internal Cli Server started on port 2223 for use by SSH.
Service guard init
Running telnetd guard thread
Running sshd guard thread
Running ntpd guard thread
Running ntpd last update time monitor thread
CRpcifBase::reportUsingUnInitializedClient(): Rpcif name 'RiLineCardCcToMaster_c', index 0 is being used while not initialized !
CRpcifBase::warnIfNotInitialized(): Rpcif name 'RiLineCardCcToMaster' is being used while not initialized !
Activating CLI Console. TimeStamp:77.
Serial CLI console started on device '/dev/ttyS1'.
BootLog: Creature 'ControlCardInit' finished.
Finished boot. TimeStamp:77.
*  Welcome to SCE8000 Version 3.6.1 Build 13.
*  Recovery mode detected, loaded with minimal hardware interaction.
*  This might result from various reasons (HW problem, explicit user request, etc.)
*  Use the 'show system operation-status' to verify the exact reason
*  You should be able to telnet to the box and install a package file
*  using the 'debug package extract system <package name>'
*  CLI command.
*  Using the logger for Dbg interpretation is possible as well.
*  Usage of any other commands might be risky, as they might
*  cause the box to get stuck !
*  Good Luck!
0 Replies 0
