WAN become intermittent when connected to LAN Switch
corneliusar
We are running GLBP on 2 router and 2 ISP and i have connected router to ISP A and already checked their bandwidth with Iperf from WAN cable and LAN cable (behind router) and no problem. But the WAN for ISP A become intermittent when i connect LAN cable to the switch even the traffic only reach 50% of our bandwidth for ISP A. I dont see any wierd logs in switch and router. I suppressed broadcast and multicast with level 20, but WAN ISP A still intermittent, it became normal when i shutdown LAN port connected to router A. I moved the port in switch and it still happen only for ISP A, no problem at all for ISP B.
What should i do with the port?
9 Replies 9
Ivan Krimmel
Level 7
Level 7
hi Cornelius,
what do you mean by the term 'intermittent'? as you said the bandwidth mark is 50%, so I hardly could imagine you are having packet loss on the WAN link A during the issue is there, am I right? is that switch connected to the rest of the network? what is the traffic rate in there? perhaps some ugly worm is probing its way out?
I think to start with we'd need to have a look at 'sh interface' from all the respective interfaces, also please do explain what is 'intermittent' in that case.
Did you try to connect the same swith to ISP_B router? Did you try to connect another switch/lan device to the router A?
HTH,
Ivan.
P.S. yes, the diagram is not opening.
Hi Ivan,
my term for intermittent means that the connection to the WAN is not consistant. As my picture above, i've connected 2 router to the same Switch to support GLBP using sub-interface. The switch connected to the rest of the network.
The WAN (10.173.3.122) become unstable or intermittent if i tried to ping it when i connect LAN port (172.22.11.2) to the switch. But there's no connection issue with Router B, only to Router A.
Here's the WAN LINK sh int from Router A
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0015.6323.2ca8 (bia 0015.6323.2ca8)
  Description: "CONECT to TELKOM VIA BRIDGE RADIO"
  Internet address is 10.173.3.122/30
  MTU 1500 bytes, BW 2560 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 46/255, rxload 73/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 31
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  5 minute input rate 742000 bits/sec, 196 packets/sec
  5 minute output rate 464000 bits/sec, 233 packets/sec
     82275468 packets input, 658555516 bytes
     Received 3389 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     80723731 packets output, 4012405773 bytes, 0 underruns
     0 output errors, 0 collisions, 16 interface resets
     24 unknown protocol drops
     0 lost carrier, 0 no carrier
Here's the LAN link sh int from Router A
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is 0015.6323.2ca9 (bia 0015.6323.2ca9)
  Description: "IP_LAN"
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 250/255, txload 3/255, rxload 2/255
  Last clearing of "show interface" counters 5d18h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 105
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1091000 bits/sec, 412 packets/sec
  5 minute output rate 1475000 bits/sec, 369 packets/sec
     114362504 packets input, 4071438734 bytes
     Received 6135713 broadcasts, 2136 runts, 0 giants, 18 throttles
     0 input errors, 0 CRC, 83 frame, 0 overrun, 0 ignored
     0 watchdog
     106840420 packets output, 73480055 bytes, 0 underruns
     68033 unknown protocol drops
Router_A#sh int f0/1.1
FastEthernet0/1.1 is up, line protocol is up
  Description: "CONECT to LAN"
  Internet address is 172.22.11.2/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1.
Here's the sh int of Switch Port from the switch connected to Router A
FastEthernet0/1 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 001e.14f4.5901 (bia 001e.14f4.5901)
  Description: LINK-TO-"TOWER_LINK_MPLS"
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 6/255, rxload 8/255
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:05, output 00:00:00, output hang never
  5 minute input rate 3529000 bits/sec, 591 packets/sec
  5 minute output rate 2468000 bits/sec, 669 packets/sec
     84250458 packets input, 62226472691 bytes, 0 no buffer
     Received 662717 broadcasts (0 multicasts)
     13 runts, 5 giants, 0 throttles
     13 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 529528 multicast, 456126 pause input
     88842036 packets output, 30837872269 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Its very confusing
Hi Cornelius,
thanks for getting back.
I would like to have a look at the same outputs taken off the part B of your setup.
Of particular interest are also 'sh policy map int for both routers A and B, as we can see the traffic-rate towards the router from the switch side is much higher than the router does afford on its WAN link, so it might be just QoS/oversubscription.
If the connection is not constant, does that mean you were able to see packets being dropped on that link? perhaps some pings were showing you some loss rate? The interface tells us 'Total output drops: 31' so I wouldn't expect a constant loss rate in there.
BR,
Ivan.
Hi Ivan,
Thanks for your response,
from ping result, i see some lost rate like this :
Reply from 10.173.3.122: bytes=32 time=92ms TTL=246
Reply from 10.173.3.122: bytes=32 time=84ms TTL=246
Reply from 10.173.3.122: bytes=32 time=61ms TTL=246
Reply from 10.173.3.122: bytes=32 time=182ms TTL=246
Request timed out.
Reply from 10.173.3.122: bytes=32 time=77ms TTL=246
Reply from 10.173.3.122: bytes=32 time=129ms TTL=246
Reply from 10.173.3.122: bytes=32 time=135ms TTL=246
Reply from 10.173.3.122: bytes=32 time=29ms TTL=246
Reply from 10.173.3.122: bytes=32 time=80ms TTL=246
Request timed out.
Request timed out.
Reply from 10.173.3.122: bytes=32 time=134ms TTL=246
Reply from 10.173.3.122: bytes=32 time=137ms TTL=246
Reply from 10.173.3.122: bytes=32 time=39ms TTL=246
Reply from 10.173.3.122: bytes=32 time=50ms TTL=246
Request timed out.
Reply from 10.173.3.122: bytes=32 time=146ms TTL=246
Request timed out.
Reply from 10.173.3.122: bytes=32 time=142ms TTL=246
Reply from 10.173.3.122: bytes=32 time=131ms TTL=246
Request timed out.
Reply from 10.173.3.122: bytes=32 time=14ms TTL=246
Reply from 10.173.3.122: bytes=32 time=42ms TTL=246
Request timed out.
Reply from 10.173.3.122: bytes=32 time=19ms TTL=246
Reply from 10.173.3.122: bytes=32 time=207ms TTL=246
Reply from 10.173.3.122: bytes=32 time=49ms TTL=246
Reply from 10.173.3.122: bytes=32 time=81ms TTL=246
Reply from 10.173.3.122: bytes=32 time=155ms TTL=246
Reply from 10.173.3.122: bytes=32 time=127ms TTL=246
Reply from 10.173.3.122: bytes=32 time=48ms TTL=246
Reply from 10.173.3.122: bytes=32 time=128ms TTL=246
Reply from 10.173.3.122: bytes=32 time=123ms TTL=246
Reply from 10.173.3.122: bytes=32 time=74ms TTL=246
Reply from 10.173.3.122: bytes=32 time=102ms TTL=246
Request timed out.
Reply from 10.173.3.122: bytes=32 time=112ms TTL=246
Reply from 10.173.3.122: bytes=32 time=96ms TTL=246
Reply from 10.173.3.122: bytes=32 time=93ms TTL=246
Reply from 10.173.3.122: bytes=32 time=60ms TTL=246
Reply from 10.173.3.122: bytes=32 time=89ms TTL=246
Reply from 10.173.3.122: bytes=32 time=181ms TTL=246
Reply from 10.173.3.122: bytes=32 time=130ms TTL=246
Reply from 10.173.3.122: bytes=32 time=136ms TTL=246
Request timed out.
Reply from 10.173.3.122: bytes=32 time=65ms TTL=246
Reply from 10.173.3.122: bytes=32 time=79ms TTL=246
Reply from 10.173.3.122: bytes=32 time=20ms TTL=246
Reply from 10.173.3.122: bytes=32 time=73ms TTL=246
Reply from 10.173.3.122: bytes=32 time=25ms TTL=246
Reply from 10.173.3.122: bytes=32 time=32ms TTL=246
here's show policy-map int f0/0 -------> WAN int router A.
Router_A#sh policy-map int f0/0
FastEthernet0/0
  Service-policy output: Manage-VPN
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 120606/17899940
    Class-map: VoIP-Control (match-any)
      120606 packets, 17899940 bytes
      5 minute offered rate 1000 bps, drop rate 0 bps
      Match: access-group name VoIP-Data
        29559 packets, 5529116 bytes
        5 minute rate 0 bps
      Match: access-group name VoIP-List
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: access-group name VoIP-Control
        74672 packets, 9577988 bytes
        5 minute rate 0 bps
      Match: ip precedence 3
        16375 packets, 2792836 bytes
        5 minute rate 1000 bps
      QoS Set
        dscp cs5
          Packets marked 120606
      Priority: 11% (281 kbps), burst bytes 7000, b/w exceed drops: 0
    Class-map: VideoConference (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name VideoIP
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (pkts output/bytes output) 0/0
      QoS Set
        precedence 3
          Packets marked 0
      bandwidth 15% (384 kbps)
    Class-map: Data-Traffic (match-any)
      436268 packets, 107479678 bytes
      5 minute offered rate 10000 bps, drop rate 0 bps
      Match: access-group name Data-List
        435702 packets, 107270174 bytes
        5 minute rate 10000 bps
      Match: ip precedence 2
        566 packets, 209504 bytes
        5 minute rate 0 bps
      Queueing
      (pkts output/bytes output) 436268/107479678
      QoS Set
        precedence 2
          Packets marked 436268
      bandwidth 40% (1024 kbps)
    Class-map: OCS (match-any)
      1576534 packets, 797223330 bytes
      5 minute offered rate 29000 bps, drop rate 0 bps
      Match: access-group name OCS
        5 minute rate 29000 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (pkts output/bytes output) 1576534/795765992
      QoS Set
        precedence 3
          Packets marked 1576534
      bandwidth 11% (281 kbps)
    Class-map: SCADA-DATA (match-any)
      0 packets, 0 bytes
      Match: access-group name SCADA
        0 packets, 0 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      QoS Set
        precedence 2
          Packets marked 0
      bandwidth 20% (512 kbps)
    Class-map: class-default (match-any)
      10706985 packets, 1588484763 bytes
      5 minute offered rate 202000 bps, drop rate 0 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
      (pkts output/bytes output) 10707197/1597113691
      Fair-queue: per-flow queue limit 16
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 0 packets
        class     Transmitted       Random drop      Tail/Flow drop Minimum Maximum Mark
                  pkts/bytes    pkts/bytes       pkts/bytes    thresh  thresh  prob
        0        10707197/1597113691      0/0              0/0                 20            40  1/10
        1               0/0               0/0              0/0                 22            40  1/10
        2               0/0               0/0              0/0                 24            40  1/10
        3               0/0               0/0              0/0                 26            40  1/10
        4               0/0               0/0              0/0                 28            40  1/10
        5               0/0               0/0              0/0                 30            40  1/10
        6               0/0               0/0              0/0                 32            40  1/10
        7               0/0               0/0              0/0                 34            40  1/10
      QoS Set
        dscp default
          Packets marked 10696522
Show policy-map int f0/1 ---->WAN interface router B
Router_B#sh policy-map int f0/1
FastEthernet0/1
      4359079 packets, 1806868564 bytes
      5 minute offered rate 6000 bps, drop rate 0 bps
        1407433 packets, 977978981 bytes
        5 minute rate 0 bps
        0 packets, 0 bytes
        5 minute rate 0 bps
        859213 packets, 166228476 bytes
        5 minute rate 0 bps
      Match: access-group 152
        12 packets, 4044 bytes
        5 minute rate 0 bps
        2092421 packets, 662657063 bytes
        5 minute rate 5000 bps
      QoS Set
        precedence 5
          Packets marked 4359079
      Queueing
        Output Queue: Conversation 265
        Bandwidth 10 (%)
        Bandwidth 307 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 7004/1493824
        (depth/total drops/no-buffer drops) 0/0/0
      0 packets, 0 bytes
        0 packets, 0 bytes
        5 minute rate 0 bps
      QoS Set
        precedence 5
          Packets marked 0
      Queueing
        Output Queue: Conversation 266
        Bandwidth 20 (%)
        Bandwidth 614 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 0/0
      6394359 packets, 818376552 bytes
      5 minute offered rate 2000 bps, drop rate 0 bps
        6394359 packets, 818376459 bytes
        5 minute rate 2000 bps
      QoS Set
        precedence 3
          Packets marked 6394360
      Queueing
        Output Queue: Conversation 267
        Bandwidth 40 (%)
        Bandwidth 1228 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 549424/69101242
    Class-map: SCADA (match-any)
      129176213 packets, 24890927800 bytes
      5 minute offered rate 291000 bps, drop rate 0 bps
        129176218 packets, 24890927775 bytes
        5 minute rate 291000 bps
      QoS Set
        precedence 3
          Packets marked 129176222
      Queueing
        Output Queue: Conversation 268
        Bandwidth 5 (%)
        Bandwidth 153 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 6511784/640586610
      114075 packets, 11866367 bytes
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/0/0
         exponential weight: 9
  class    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
      0  114075/11866367        0/0              0/0           20      40  1/10
   rsvp       0/0               0/0              0/0           36      40  1/10
      QoS Set
        dscp default
          Packets marked 0
Please help me to analyze this
Thank you
You have a cable problem. The "reliability" value should be 255/255
Hi Leolaohoo,
If the LAN interface cable is the problem, then why  unstable connectivity happen on WAN interface when i try to ping the WAN  IP address from the opposite router?
BR,
0 watchdog
Hi Cornelius,
Maybe I'm wrong.  But something just DOES NOT ADD UP with your initial post.
According to your initial post, this interface's counters was cleared  "5d18h".  Look at the "Total output drops".  That's not good.  Next, look at the input and output errors.  Input has some "frame" errors.  Output has "unknown protocol drops".  Of course the "reliability" is 250 is another thing.
I'm no expert what "frame" and "unknown protocol drops" errors are but my first reaction would be to swap out the cable.
Hi Cornelius,
thanks for additional outputs. Let's have a look at 'sh interface' outputs taken off the leg B of your topology, like you have done before for the leg A - from the router B interfaces, and the switch interface towards router B. As I said, I would like to narrow down the QoS/oversubscription matter.
Have a great day,
Ivan.
Hi Ivan,
Sorry i forgot to add some informations from router B,
WAN int Router B
Router_B#sh int f0/1
  Hardware is Gt96k FE, address is 0015.6322.e227 (bia 0015.6322.e227)
  Description: **\Link to VPN-IP XL/**
  Internet address is 10.172.179.150/30
  MTU 1500 bytes, BW 3072 Kbit, DLY 100 usec,
     reliability 255/255, txload 27/255, rxload 60/255
  Input queue: 0/75/3995/0 (size/max/drops/flushes); Total output drops: 0
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 4/4 (allocated/max allocated)
     Available Bandwidth 2 kilobits/sec
  5 minute input rate 726000 bits/sec, 236 packets/sec
  5 minute output rate 332000 bits/sec, 194 packets/sec
     156232219 packets input, 2807704202 bytes
     Received 32154 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     146465380 packets output, 1752281153 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     31348 unknown protocol drops
LAN int Router B
Router_BI#sh int f0/0
  Hardware is Gt96k FE, address is 0015.6322.e226 (bia 0015.6322.e226)
     reliability 255/255, txload 2/255, rxload 1/255
  Input queue: 0/75/2512/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 642000 bits/sec, 298 packets/sec
  5 minute output rate 1095000 bits/sec, 318 packets/sec
     238800808 packets input, 3756944872 bytes
     Received 19010019 broadcasts, 0 runts, 0 giants, 0 throttles
     139 input errors, 0 CRC, 0 frame, 0 overrun, 139 ignored
     0 watchdog
     230144780 packets output, 723397526 bytes, 0 underruns
     0 output errors, 0 collisions, 11 interface resets
     310161 unknown protocol drops
Router_B#sh int f0/0.1
FastEthernet0/0.1 is up, line protocol is up
  Description: **\Link to LAN Kaji/**
  Internet address is 172.22.11.3/16
LAN port Switch to Router B
SWITCH#sh int f0/1
     reliability 255/255, txload 6/255, rxload 9/255
  Last input 00:00:02, output 00:00:00, output hang never
  5 minute input rate 3603000 bits/sec, 645 packets/sec
  5 minute output rate 2515000 bits/sec, 692 packets/sec
     128634784 packets input, 94510942305 bytes, 0 no buffer
     Received 963880 broadcasts (0 multicasts)
     52 runts, 14 giants, 0 throttles
     52 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 753560 multicast, 851613 pause input
     136154948 packets output, 47901012787 bytes, 0 underruns
