SDM and Config Editor
saugustin
While enabling the firewall in SDM, it wiped out the cmd "login local" on my "line con 0". I am not able to find a tool in SDM to add the cmd back in except for ConfigEditor, but I do not know the syntax. I just want to be able to merge the new command back into my running config.
Giuseppe Larosa
Hello Steve,
if you have telnet or ssh access to the box you can use CLI
telnet box-address
use the user/pwd needed
get enable access
router> enable
router# conf t
router(config)# line con 0
router(config-line)# login local
router(config-line)#end
test console access then if everything is fine:
router# write mem
a username/pwd pair must exist to use this.
Hope to help
Giuseppe
