SDM Security
toddmanger
I have installed SDM on a 2811 router and it works great.
The issue that I need to correct to disallow access to SDM from our public IP address (204.x.x.x brings up prompt to enter router username and password.
How do I limit use of SDM to only the private LAN or VPN address?
spremkumar
Level 9
Level 9
Hi Todd
You can make use of the command ip http access-class which can help you out to restrict the access to the router via HTTP.
for more help on the configurations do refer this link ..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tnm_r/nmg_02ht.htm#wp1125783
regds
