SDSL configuration
yepweizhi84
Community Member
I plan to remove the SDSL ISP modem and install SHDSL module into my Cisco 2901 and configure with the information below.
ISP IP: 192.168.1.2/30
ISP GW:192.168.1.1
Usernam:aaa@bbb
Password:cccc
LAN IP: 10.100.100.0/24
LAN GW: 10.100.100.1
If i reffering to this website http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a59c.shtml
there is no username and password need to configure on the router itself, how the ISP can be connected?
paolo bevilacqua
That can be a PPPoA connection requiring username and password.
Thanks for the reply Paolo
Reffering to the example, i able to put in the ISP IP and route to ISP gateway but there is not username and password configure.
can you share with me how to put in the static ISP IP addressand route to ISP gateway with PPPoA configuration?
In cisco.com search "PPPoA example".
But first confirm with ISP if PPPoA is used, and the VPI/VCI values.
