SDSL on Cisco 888E
Audric Gbt
I'd like to configure my Cisco 888E to use for a VDSL connection via the SHDSL interface, but can't quite apply my PPP information on it. Can you guys help me ? Here's what i got so far :
xxx#sh run
Building configuration...
Current configuration : 1831 bytes
! Last configuration change at 11:25:52 UTC Thu Jan 20 2022
version 15.2
no service pad
service password-encryption
hostname xxx
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 192.168.1.1
ip dhcp pool CLIENT
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.1.1
ip domain name xxx
ip cef
no ipv6 cef
license udi pid CISCO888E-K9 sn xxx
username admin privilege 15 password xxx
controller SHDSL 0
description PPP:SDSL
ip ssh version 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip nat inside
ip virtual-reassembly in
interface Dialer1
mtu 1460
ip address negotiated previous
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1450
load-interval 60
dialer pool 1
dialer-group 1
ppp authentication chap
ppp chap hostname xxx@xxx
ppp chap password xxx
ppp pap refuse
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list lanclient interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard RemoteManagement
permit any
ip access-list standard lanclient
permit 192.168.1.0 0.0.0.255
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
ntp server xxx
end
what information are you trying to add exactly ? As far as I recall, the 888E router supports only EFM over G.SHDSL. With your current configuration, do you actually get an IP address ?
