Secondary IP and Subinterface
m.metwally
Dear All,
what's difference between setting secondary IP on the same interface and using two Subinterfaces ?
Marwan ALshawi
the secondary interface will be use to communicate using another IP subnet but with oruting wil not be considered as the rotuing will consider the main primary interface IP
can be used with static route
subinterface is as you have difrent interface the given Ip will be considered as primary IP at that subinterface
also if you have an ethernet interface connected to trunk you can you the subinterfaces as each one i diffrent VLAN this helps in tinter vlan routing also known as router-on-stick
with frame-relay subinterfaces can be put each in diffrent DLCI so they operate thorugh diffrent circuit
if helps Rate
