10-15-2011 11:29 PM - edited 03-05-2019 06:46 AM
I'd like to enable any firewall features and block any incoming WAN traffic (except for PPPoE negotiaition and return inside traffic) as we use another DSL for incoming to servers.
Will just be used for outgoing port 80,443.
Could anyone guide as to what to do here?
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ADSL1841
boot-start-marker
boot system flash:/c1841-advipservicesk9-mz.124-22.T1.bin
boot-end-marker
logging message-counter syslog
logging buffered 51200
logging console critical
enable secret 5 $1$qZO0$nP19varmjKm89.UVXNO260
no aaa new-model
clock timezone PCTime 8
dot11 syslog
no ip source-route
ip cef
no ip bootp server
ip domain name adsl1841.com
ip name-server 203.0.178.191
ip name-server 192.168.1.12
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 10
no ip ftp passive
interface FastEthernet0/0
description $ES_LAN$
ip address 10.98.8.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
atm ilmi-keepalive
bundle-enable
interface ATM0/0/0.2 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
no ip virtual-reassembly
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname *******
ppp chap password 7 ******
ppp pap sent-username ******!
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.98.0.0 255.255.0.0 10.98.8.1
ip route 192.168.1.0 255.255.255.0 10.98.8.1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
logging trap debugging
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 10.98.0.0 0.0.255.255
dialer-list 1 protocol ip permit
snmp-server community cisco RW
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
password 7 0207175F0D575D7218
login
scheduler allocate 4000 1000
end
Thanks for your help!
Solved! Go to Solution.
10-16-2011 11:45 PM
I had entered the command by heart but indeed I made a mistake for this one, here is the correct syntax:
zone-pair security
Regards.
Alain.
10-16-2011 12:58 AM
if it is supported on your platform you can use CBAC or ZBF which are 2 stateful firewalling features, the lattest being the new way.
1)CBAC
config# ip inspect log drop-pkt
config# ip inspect MYFW tcp
config# ip inspect MYFW udp
config# ip access-list extended INSIDEACL
permit tcp any any eq 80
permit tcp any any eq 443
permiit udp any 203.0.178.191 eq 53
config# ip access-list extended OUTACL
deny ip any any
config# int f0/0
ip access-group INSIDEACL in
config# int Dialer1
ip access-group OUTACL in
ip inspect MYFW out
2) ZBF
config# zone sec IN
config# zone sec OUT
config# class-MAP type inspect match-any IN_OUT
match access-group name INSIDEACL
config# policy-map type inspect IN_OUT_INSP
class type inspect IN_OUT
inspect
config# int f0/0
zone sec IN
config# int dialer1
zone sec OUT
config# zone-pair sec source IN destination OUT
service-policy type inspect IN_OUT_INSP
Regards.
Alain.
10-16-2011 09:08 PM
Thanks, I configured the Zone Based Firewall with the following commands...
zone sec IN
zone sec OUT
permit udp any any eq 53
inspect
int f0/0
zone sec IN
int dialer1
zone sec OUT
Its just that when I input the command below, the router wouldn't let me use it
It only let me input:
zone-pair sec source source IN destination OUT
or
zone-pair sec source source zone IN destination OUT
So I used source. Is this correct or should I have input source zone?
Other than that, the commands were input sucessfully
Please let me know which command to use,
Thanks...
10-16-2011 11:45 PM
zone-pair security
Regards.
Alain.
10-17-2011 12:02 AM
You Rule!!!
THANKS!!!
