09-10-2008
04:13 PM
- last edited on
03-25-2019
03:20 PM
by
ciscomoderator
I'm studying for CCNA. How do I download the application on to my computer? And how do I confirm that it is on my 1841?
09-10-2008 04:32 PM
Cliff,
You can download SDM from the link below. SDM can be installed on your PC, router or both. If you choose to install it to flash on your router you can issue the "show flash:" command and you will see many additional SDM files. I would recommend reading the release notes and documentation carefully and get a firm understanding of the GUI and it's features. You will also need to add some commands for SDM functionality found in the documentation.
http://www.cisco.com/cgi-bin/tablebuild.pl/sdm
HTH,
Mark
02-27-2019 07:20 AM
Not Found The requested URL /cgi-bin/tablebuild.pl/sdm was not found on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
02-27-2019 11:01 AM
SDM is no longer supported. Try Cisco ccp.
