seems IOS is 99% Similar to XE , so what is the difference other than Monothilic and linux kernel
Ibrahim Jamil
Level 6
Level 6
Hello
thanks all in advance for ur answering
Rolf Fischer
Level 9
Level 9
IOS-XE supports multi-core CPUs.
Another advantage of having a underlying Linux OS is that you easily can run applications like WireShark or WLAN controllers on it.
Here you can find a nice document with more details: What is Cisco IOS XE?
Rolf
thanks mate
looks like Cisco will retired IOS soon
Joseph W. Doherty
BTW, since IOS predates XE, one might say XE is 99% similar to IOS, not the converse.  ;)
