Bookmark
Subscribe
676
Selecting an IOS version - specific command needed
Greetings,
We are working on a configuration that requires a specific command. Apparently, that command is not included withe version of IOS we have on this device. Here's the details of the switch and current IOS:
Cisco Catalyst 3560G-48PS Switch v15.0.2
c3560-ipservicesk9-mz.122-53.SE2.bin
The command we're trying to use is:
  • sdm prefer extended-match
http://www.cisco.com/c/en/us/support/docs/ip/ip-routed-protocols/47900-cat3550pbr.html
I would think IP services would include this, however, the version we have is old. In trying to upgrade, we were not licensed for the newer version of ipservices (and we're trying to work through that). So, would a newer version of IP Services have this command?
Chris
cadet alain
This is not a valid SDM template for the 3560.
Alain
Thanks for the quick response. Can you suggest an alternative?
if this is to implement PBR then use sdm prefer routing template
Alain
