Showing results forĀ
Search instead forĀ
Did you mean:Ā
send traffic up to line rate ( 1Gbps)
Ibrahim Jamil
Level 6
Level 6
Hello guys
I have 1G Committed Pipe between Point A (ASR1000) and Point B (ASR1000)
I need to test the link , how can i send traffic up to line rate ( 1Gbps)
thanks all
Hi!
You can also use this traffic generator which is just an application you can download it from the web site. Please refer to the following document authored by me for details:
https://supportforums.cisco.com/document/13016006/easy-traffic-generator-works-gns3
Hope it helps, best regards!
JC
11 Replies 11
Nagendra Kumar Nainar
You may need some traffic generators like IXIA, Spirent etc.
Hi nagendra
this is a devices , ex spirent , right
can i achieve the same as paul mentioned via MQC
thanks
Hi Ibrahim,
Yes, it is a device to pump traffic. Ping is one way of generating traffic, but i think it might be hard to get line rate of traffic. The other option is to configure multiple IP SLA with less frequency and bigger packet size.
-Nagendra
Hi!
JC
Hi Carlos
I would use urs
thanks to u and to all guys
Hello
Apply a continuous ping from one asr to the other with a large packet size and (assuming no other traffic is ring used)
Then on the receiving asr apply a policy map to capture the traffic
policy-map Test
Class class-default
int x//x
load-interval 30
service policy input Test
Res
paul
Kind Regards
Paul
Hi Paul
do i need any class-map
shall the ping < other end > size <1gb> enough to let PRTG show me the pipe is fully utilized
thanks
Hello
No need for a class map as you are matching on any traffic hitting the other rtr, Unless you do have other traffic traversing the link at the same time and want to match on say specific ICMP.then yes use a class-map and possibly an acl aswell to match on protocol and source
Forgot to mention to post the show command for the receiving rtr policy map
sh policy-map interface x/x
res
Paul
Kind Regards
Paul
I would use two PC (one connected to each router) with iPerf to test it.
Hi karsten
mate , do you have how the config on java iPref looks like ???
thanks mate in advance
Never used the Java version, but there are numerous howtos on the internet like the following:
http://www.openmaniak.com/iperf.php
