separate Voice & Data
the company i know wants there voice and data network separate. and they want to use the following topology.
will it work, and suitable, what are issues applying this topology. thanks for your advice
thanks
shameer
mvsheik123
Level 7
Level 7
I never worked on UC560 and SA-520 but I guess theuy must support 'Nat' and general routing (atleast static). Based your diagram it will work if you place DATA and Voice on 2 seperate subnets and not looking to have any commnucation between. One thing.. when the traffic hit the internet both share the same link. So you may need some QOS at internet edge and may want to consider L3 switch.
Hth
MS
