Serial Communication between two PC's using router
singraj2001
Two routers are configured back to back frame-relay connection for the purpose of getting communication between two PC’s through serial communication(Not IP based). There are no problem between frame relay, can able to ping each other. but cannot communicate two Pc's using serial port.
Example Diagramand configuration- Attached on the post.
Now if i connect CaMaU the Com port using router serial DB9-RS232 link its go to router prompt. And PC-A system also the same.
BR-A Router Configuration
interface Serial0/0/0
description *** Link to BR-A ***
bandwidth 64
no ip address
encapsulation frame-relay
load-interval 30
no keepalive
max-reserved-bandwidth 100
interface Serial0/0/0.300 point-to-point
description *** PVC to BRA ***
bandwidth 64
ip address 192.168.10.10 255.255.255.252
frame-relay interface-dlci 300 CISCO
  class BRA
interface Serial0/0/1
physical-layer async
description ** MODBUS data From BR-A **
no ip address
load-interval 30
keepalive 10
line con 0
login local
line 0/0/1
exec-timeout 0 0
transport preferred telnet
transport input all
transport output all
autohangup
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
password cisco
login local
transport input telnet ssh
CaMaU Router configuration
bandwidth 64
no ip address
load-interval 30
no keepalive
description *** 64K PVC to CaMau office ***
bandwidth 64
ip address 192.168.10.9 255.255.255.252
no ip address
encapsulation slip
load-interval 30
no peer default ip address
keepalive 10
line 0/0/1
transport preferred none
transport input all
Please anyone review the configurations and let us know your suggestion. Thanks
aqeel.karim
I'm sure alot of things are possible. But when I look at what your asking, correct me if I'm wrong... You want BR-A to pass PC-A signal to PC-B via your CaMaU router. I look at this similar to an ISP passing a T1 signal from one site to another.
To me there is a disconnect between each sites internal to external int's. I don't see how you are associated BR-A inside interface to its outside interface. So, essentially, you want to router to route traffic without telling it to route something. To eliminate L3 you would need some kind of L2 tunneling protocol that will pass seemingly through the Frame-Relay connection.
And maybe, I'm an advocate for L2TPv3 but this seems like a tool that may be needed.
My first questions would be: Do you have registered MAC addresses for the PC's in the routers MAC table? If not, you have a L1 issue that you would need to resolve first. I'm going to see if, I can lab this up, but I can't get pass how to make a strickly L3 device into a L2 only device and pass IP based traffic.
What traffic are you looking to pass w/o using an IP? Even ICMP is a mild form of IP. So, even a ping test cannot be accomplished without an IP addr.
Standby....
Look at the following articles
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_tech_note09186a00800b451e.shtml#stunconfig
or the root
http://www.cisco.com/en/US/tech/tk827/tk369/tech_configuration_examples_list.html
Hi karim,
Thanks a lot for your reply,
I describe the scenario and I need to clarify few things to you,
Sorry, In my last configuration I forgot to add encapsulation slip on serial 0/0/1.(See the new attachment)
My customer want to access PC-A to PC-B which is PLC (PC-A and PC-B-PLC) which only knows Serial communication language ( Modbus). And its passing through Vsat which is S0/0/0. We can able to reach from BR-A to BR-B (CaMaU) through V-Sat. But from the PC-A and PC-B cannot access. Using the existing configuration able to access PC-A to PC-B. Attached the existing configuration in the post. But due to some reason cannot access now.
We suspect the cable could be a problem (DB60 – RS232 – DB9) and changed still the same.
But we try to simulate the same scenario in our lab, Using back to back frame relay and using the encapsulation SLIP for the S0/0/1 interface on both side Which is almost same config. From the router can able to reach each other. But from the PC-A and PC-B cannot access.
Objective - From PC-A using Hyper terminal whatever I type should see (PC-B) other end and could not see the anything from PC-A.
If I am not wrong we do not need to see our PC Mac address on the router ARP table which we did not connect the Ethernet.
Thanks once again for your understanding. Please let me know if you need more clarification.
Thanks for the detailed config and drawing. I think, I understand what you are trying to accomplish. But to go back to a layered approach, I see on RouterA S0/0/1 doesn't have a L1 connection, something isn't there.
But when you get L1 working, I think you are trying to telnet from PC-A to PC-B. I'm at a lost on how to accomplish this without some kind of IP networking. But in the documents I attached there are Cisco methods of passing L2 traffic w/o a L2 addr. Standby as I try to lab this up.
Aqeel
