Serial DTE/DCE connection between routers in real life
TomCom01
Hi, I'm currently studying for the ICND1 CCENT exam. I'm reading Wendell Odom's official cert guide. In Chapter 3, he wrote that a serial connection with a DTE and a DCE cable can be used for a lab. However, is there an application in real life, too? I know that in real life a CSU/DSU sets the clock rate, hence it is the DCE, isn't it? Nevertheless, is there any use for a serial connection with a DTE/DCE cable in real life, too or is it just for lab?
Thanks for support!
I guess you are right, the serial DCE/DTE cable is used in labs, in order to configure two routers back to back, and in order to simulate a WAN connection. I have never seen it in a real, live network, it wouldn't work well anyway since you are limited by the length of the cable (3meters max as far as I remember).
That said, serial connections (if you exclude the high speed HSSI links which support speeds up to 52MB) themselves have become rare, since they only support speeds of 4MB max.
Thanks, I think I understand this now. However, external CSU/DSUs are connected via a serial cable to the router in real environments, aren't they? So, support this link just 4MB, too?
a very long time, let's say 15 years  ago, a T1 (1,5MB) was considered an ultra high speed connection. Nowadays you get 100MB to your home for 30 dollars a month. I haven't seen a serial connection in a real, live environment for ages. The technology is completely outdated, similar to frame relay. 4 to 6MB was max indeed...
