Serial Interface Queue Drops
Recently, I started monitoring the T1 interface and noticed that input queue has drops as well as having alot of total output drops. Below is the line from the show interface after 8 hours.
Input queue: 0/75/17/0 (size/max/drops/flushes); Total output drops: 22747
From my initial reading it appears that I may want to start using a different type of queue. It is currently set to FIFO. Attached is the complete "show interface"
I was hoping that somebody would be able to shed a little more light on my issue. As well as some possible avenues to take.
Thanks in advance for any assistance.
Here is the attachment
The input queue drops are small enough that I would not not be too concerned about them. However, the output drops are a bit of a worry. When did you last clear the counters ? It might be worthwhile to clear the counters and observe over a 5 minute period to see if it is a regular occurrence. It could be possible that the drops occurred as part of a burst of traffic and are not regular.
Hope that helps - pls rate the post if it does.
Paresh
