Serial interfaces Link Status Down.
nahidhossain1
Dear All,
I've installed E1 card (VWIC3-4MFT-T1/E1) in cisco 2911 router (IOS version 15.4) and configured accordingly. But  Link Status of serial interfaces
down. Here is the  Card configuration and Sh interface serial 0/0/0:0 commands result-
Card Configuration:
Step:1
card type e1 0 0
card type e1 0 1
Fast Card Interface Configuration
controller E1 0/0/0
 framing NO-CRC4
 channel-group 0 timeslots 1-31
controller E1 0/0/1
 framing NO-CRC4
controller E1 0/0/2
 framing NO-CRC4
controller E1 0/0/3
 framing NO-CRC4
Second Card interface configuration
controller E1 0/1/0
 framing NO-CRC4
controller E1 0/1/1
 framing NO-CRC4
controller E1 0/1/2
 framing NO-CRC4
controller E1 0/1/3
 framing NO-CRC4
And here is the serial interface status:
sh interfaces serial 0/0/0:0
Serial0/0/0:0 is down, line protocol is down
  Hardware is DSX1
  MTU 1500 bytes, BW 1984 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, crc 16, loopback not set
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     1 carrier transitions
So what is the problem and how can i up the link status?
rosaho
Level 3
Level 3
This discussion has been reposted from Community Ideas to the WAN, Routing and Switching community.
