serial port problem
Ameer Mlaghee
Hi all,
please refer to the problem below that I face it in the new WIC that I installed in Router 2811, and let me know how to fix it ?
by the way, the other side of serial cable attached in router 1841, and there is no problem either L1 or L2.
Thank you.
R1#sh ip inter b
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  administratively down down
Serial1/0                  10.1.1.1        YES manual up                    down
Serial1/1                  unassigned      YES unset  administratively down down
Serial1/2                  unassigned      YES unset  administratively down down
Serial1/3                  unassigned      YES unset  administratively down down
R1#sh controllers s1/0
CD2430 Slot 1, Port 0, Controller 0, Channel 0, Revision 19
Channel mode is synchronous serial
idb 0x4687D79C, buffer size 1524,Unknown (85)  cable
Global registers
  rpilr 0x2, rir 0x0, risr 0x0, rfoc 0x0, rdr 0x0
  tpilr 0x1, tir 0x0, tisr 0x68, tftc 0x0, tdr 0x0
  mpilr 0x3, mir 0x0, misr 0x40
  bercnt 0xFF, stk 0x0
Per-channel registers for channel 0
  Option registers
  0x02 0x00 0x42 0x67 0x60 0x00 0x00
  Command and status registers
  cmr 0xC0, ccr 0x00, csr 0x8C, msvr-rts 0xE1, msvr-dtr 0xE1
  Clock option registers
  rcor 0x80, rbpr 0x81, tcor 0x00, tbpr 0x81
  Interrupt registers
  ier 0x89, livr 0x00, licr 0x00
  DMA buffer status 0x20
  DMA receive registers
  arbaddr 0xF6F6F04, arbcnt 1548, arbsts 0x1
  brbaddr 0xF6F6884, brbcnt 1548, brbsts 0x1
  rcbaddr 0x0
  DMA transmit registers
  atbaddr 0xF70A414, atbcnt 24, atbsts 0x62
  btbaddr 0xF70A554, btbcnt 24, btbsts 0x62
  tcbaddr 0xF70A56C
  Special character registers
  schr1 0x00, schr2 0x00, schr3 0x00, schr4 0x00
  scrl 0x0, scrh 0x0, lnxt 0xE1
Driver context information
  Context structure 0x4687F974, Register table 0xB9800400
  Serial Interface Control 5:1 Register (0xB9800802) is 0x80
  Adaptor Flags 0x0
  Serial Modem Control Register (0xB9800804) is 0x1D
  Receive static buffer 0x46880E40
  Receive particle buffers 0x4687FFC0, 0x4687FF80
  Transmit DMA buffers 0x0, 0x0, 0x0, 0x0
  Transmit packet with particles 0x0, first word is 0x0
  Interrupt rates (per second) transmit 0, receive 0, modem 0
  True fast-switched packets    0
  Semi fast-switched packets    0
  Transmitter hang count        0
  Residual indication count     0
  Bus error count       0
  Aborted short frames count    0
  CRC short frames count        0
  Tx DMA low threshold count    0
Error counters
  CTS deassertion failures      0
  Nested interrupt errors transmit 0, receive 0, modem 0
R1#sh inter s1/0
Serial1/0 is up, line protocol is down
  Hardware is CD2430 in sync mode
  Internet address is 10.1.1.1/24
  MTU 1500 bytes, BW 128 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input never, output 00:00:02, output hang never
  Last clearing of "show interface" counters 03:00:30
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     14 packets output, 623 bytes, 0 underruns
     0 output errors, 0 collisions, 26 interface resets
     0 unknown protocol drops
     19 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Richard Burts
There is not enough information here for us to accurately identify the issue. Can you provide the equivalent information from the 1841? It might also be helpful if you would post the configuration of the interface from both routers.
Rick
Rick
