Service compress-config
feng.yan
Hi guys,
on the cisco 4948 switch, I always get an error message says 'Compress config cannot be disabled' when I try to disable 'service compress-config'. Dose anybody know the reason? Thanks in advance!
n.nandrekar
Level 4
Level 4
hi!
For the Cat4000/4500, the service compress configuration command is a fixed configuration, in the sense that we can not turn that service off.
It shouldnt cause any problems though. Any specific reason you are trying to turn it off?
Niranjan
Thanks Niranjan!
No specific reason...
If I configure this command while it has many services, will it impact to my services
