Hello all,
I have a problem with the switch module in Cisco Router 2911/switch module 3560E.
It was working everything ok when it suddenly lost connection.
When I try to log in via router its stuck in:
Router#service-module gigabitEthernet 1/0 session
Trying 10.140.10.1, 2067 ... Open
The output from the service status:
Router#service-module gigabitEthernet 1/0 status
Service Module is Cisco GigabitEthernet1/0
Service Module supports session via TTY line 67
Service Module is failed
Service Module reset on error is disabled
Service Module heartbeat-reset is enabled
Service Module status is not available
I can login to router via ssh, but not via console so I cannot get logs from the boot.
Solutions I have tried:
1.service-module gigabitEthernet 1/0 reset
2.Reboot router/switch
3.Remove switch module physically and put back in.
Would appreciate any kind of help,
Thanks!
